To Multibridge or not at DVinfo.net
Old July 20th, 2010, 09:44 AM   #1
Do I need a Blackmagic Design Multibridge Pro just to edit 2K (2048x1556 @ 25fps) in 10bit RGB 4:4:4 (or sometimes even) better in Vegas?
Currently I don't need the HDMI- or HD-SDI i/o but I would like to display 10bit colors on a display.
Does video playback nicely on a top-range GeForce based card in combination with a calibrated dual-DVI monitor?
Would you advise to install a second multi-CPU environment with SLI - would Vegas benefit from this?
Would CUDA be helpful?
I'm going to build a new PC so I can use suggestions.
Vincent Mesman is offline   Reply
