Need a .mov file, render settings at DVinfo.net
Old July 21st, 2010, 10:07 AM   #1
Need to convert my avi files from a shoot to .mov so they can be edited on an Apple. Files are 720x480 SD. Do I simply choose uncompressed .mov for my setting? So far it's halfway through and its already 64 GB in size. Yikes
Old July 21st, 2010, 01:25 PM   #2
Sponsor: JET DV
Uncompressed will be huge just like uncompressed AVI files are huge. If the files are DV, you simply need to render to DV-MOV which should be the exact same size.
Old July 21st, 2010, 03:45 PM   #3
Edward, I can find nothing like DV-MOV in the render settings under quicktime templates.
Old July 21st, 2010, 04:18 PM   #4
(assuming YUV)
Render As > QuickTime > Default Template
Frame size: 720x480 (NTSC DV)
Frame rate: 29.97 (NTSC)
Field order: Lower field first (assuming interlaced)
Pixel Aspect Ratio: 0.909
Video format: DV/DVCPRO - NTSC > Configure (***)
***Scan Mode: Interlaced (assuming interlaced!)
***Aspect Ratio: 4:3
Compressed depth: 24bpp color
Quality: 100.0%
and Audio of course will be 16bit Stereo 48kHz as usual.
(if i remember correctly, output file size is about 220 Megs per minute)
hth
Rob Wood is offline   Reply With Quote
Old July 23rd, 2010, 06:26 AM   #5
Rob, thanks for your response, but the file output is still extremely large.
I'm stuck holding this client's footage until I can come up with settings for this.
Old July 23rd, 2010, 07:19 AM   #6
Sponsor: JET DV
And you set the format to DV? That should have given you files roughly 13Gig/Hour - the same a DV-AVI files.
Old July 23rd, 2010, 12:43 PM   #7
Yes, here were the settings in case I missed something.
Old July 23rd, 2010, 02:30 PM   #8
Sponsor: JET DV
Yes, you missed something. The "Video Format" should be set to the appropriate DV setting. There are three to choose from: DV-PAL, DV/DVCPRO - NTSC, and DVCPRO - PAL.. Using those settings, you're getting "uncompressed" which is HUGE.
Old July 23rd, 2010, 02:35 PM   #9
Thanks for your response Edward, I really appreciate it!
