Master Audio Effects in V10 Plugin Problem at DVinfo.net
Old November 6th, 2010, 08:58 AM   #1
I just upgraded to V10 and am having a problem trying to apply effects to the master surround in V10. I loaded 3 video w/ audio tracks onto the timeline. When I try to apply any of the standard effects to the Master in the Mixing Console window I get a message "The plug-in could not be run." Under details it says "Plugin does not support required connection".
The plug-ins are working on the individual tracks.
All of the plug-ins worked fine with V9 on the Master.
Any ideas would help. Thanks
Jim
Jim Schuchmann is offline   Reply With Quote
Old November 6th, 2010, 11:35 AM   #2
yep i can 2nd that.
had the same experience when i tried to set a high-pass filter on a 5.1 mix we had some problems with. also tried waves hammer surround.
same message as OP.
don't think it matters but...
Vegas 10a
Win7 Pro 64bit
4GB RAM
XEON E5440 2x2.83G
NVIDIA Quadro FX 3700
Rob Wood is offline   Reply With Quote
Old November 6th, 2010, 12:41 PM   #3
I posted this on SCS forum for Vegas Pro and received a response that it is a reported bug in 10a and should be fixed in 10b.
