51 minutes of video in DVDARCH, best setting 4 the best quality - Page 2 at DVinfo.net
Old August 6th, 2011, 10:42 AM   #16
Re: 51 minutes of video in DVDARCH, best setting 4 the best quality
Originally Posted by Phil Lee View Post
and who uses PCM these days?
I do! I hate lossy compression of sound even more than I hate lossy compression of video.
Adam Stanislav is offline   Reply With Quote
Old August 6th, 2011, 10:44 AM   #17
Being able to push the upper limit was one reason why I upgraded my NLE software. I shoot for 8500 CBR with AC3 audio added to that. After 1,000's of replicated disks I have never had one returned for failure to play.
Old August 6th, 2011, 11:59 AM   #18
Hi
So no 5.1 then?
Sounds like you need Blu-ray :-) Personally I don't put my own video on DVD anymore, it's all Blu-ray HD now plus you can go for lossless audio at higher sampling, even with 5.1 or better.
Regards
Phil
Phil Lee is offline   Reply With Quote
Old August 14th, 2011, 06:52 AM   #19
Hola,
Guys i followed your instruction for my 48 minutes dvd:
I set CBR to 8000
and for the audio i rendered to AC3pro, du t i wanted to ask if for the audio i should custom anything like u makde me do on CBR for the video...
Thank you
Old August 14th, 2011, 07:51 AM   #20
Burn one DVD and listen to it through a decent stereo system.
If you find that the volume is too low, try the following adjustments.
Encode set to AC3;
Click on Custom tab;
On the first tab, set Dialog Norm at -31 (this sets it at unity gain);
On the last tab marked Preprocessing, set the Line Mode Profile and RF Mode Profile mode to "none";
Save this as a preset.
Old August 14th, 2011, 09:35 AM   #21
Mike u know what?
The dvd listened on my bran new home system is lower than the normal...
i'll do as suggested and i'll let u know!
Thx mate!
Old August 16th, 2011, 10:57 AM   #22
Jubal 28
Unless you absolutely know what you're doing, I'd use the standard DVD Architect templates under MPEG-2. They're already optimized.
The ONLY change I'd make is if you're rendering HD footage -- change the Video quality to BEST because you're resizing the footage. But if it's SD footage all along, I wouldn't touch it.
David Jimerson is offline   Reply With Quote
Old August 20th, 2011, 04:37 AM   #23
The source footage is HD 1080 50 i but o have to make dvds for SD viewers. So i matched the project properties with the render roperties to have pladv widescreen Pal.
Now you suggestto put "best" on the final option render?
Old August 20th, 2011, 07:58 AM   #24
Sponsor: JET DV
Yes, Marcus, change the rendering to "Best" because it is now resizing the video.
Old August 23rd, 2011, 06:58 AM   #25
Thank you guys!
Old August 23rd, 2011, 11:56 AM   #26
When you say best you mean the BEST option n the properties custom tab?
Right now i just set CBR 8.000
Marcus Martell is offline   Reply
