color curver adjustment missing at DVinfo.net
Old December 7th, 2012, 10:28 PM   #1
This is annoying. In V12, whenever I apply 'color curves' to a clip and make some adjustment. If I Open another V12, cut or copy the clip to the new V12. You will find the adjustment did not get copied over.
V11 and earlier versionl do not have this issue. Am I missing something or should I open a case with Sony?
Sony PMW-EX1, Canon 5DM2,60D, HV20, Sony Vegas 11
John Woo is offline   Reply With Quote
Old December 8th, 2012, 03:08 AM   #2
Re: color curver adjustment missing
I had the same issue when I tried to move project to the other workstation, but I applied curves to cub-clips.
Juris Lielpeteris is offline   Reply With Quote
Old December 8th, 2012, 06:26 AM   #3
John, you're not missing anything and this should be reported to Sony as I have experienced this myself along with several other users. The more of us that report it as a bug, the better the chance we have of getting it fixed in a future update.
https://www.custcenter.com/app/ask
Old December 8th, 2012, 06:38 AM   #4
I have logged a case with Sony.
Old December 8th, 2012, 07:24 PM   #5
Even with just 1 complaint, Sony should fix it immediately. This is obviously an over sight by the programmer who failed to port over the code from V11 to V12. After so many version and Build this kind of mistake still exist clearly show dis-organise within the organisation.
Old December 9th, 2012, 08:20 AM   #6
John, it gets even stranger. Graham Bernard reported on another forum (where a user had the exact same issue) that he had no problems doing a copy/paste of event attributes with a different FX (in his case, Bump Map). This is definitely a coding problem which Sony should hopefully be able to sort out fairly easily.
Old December 9th, 2012, 05:05 PM   #7
Old Boot
Yes, correct.
G
Old December 18th, 2012, 04:27 AM   #8
this problem only happens on Color Curve and Color Match fx only.
Other FXs no issues.
Setiawan Kartawidjaja is offline   Reply With Quote
Old January 30th, 2013, 07:58 PM   #9
Got a reply from Sony. I downloaded the new version and yes it has been resolved
"Thank you for contacting Sony Creative Software.
An update for Vegas Pro 12 was released today which resolves some issues related to this incident. You may download the new update here. Sony Creative Software - Download: Vegas Pro 12.0
