Multitrack audio import script? at DVinfo.net
Old December 15th, 2012, 11:49 AM   #1
Anybody know of a vegas script to distribute individual audio files across tracks on import or from the media bin?
I've just received a kajillion audio files with the naming below. No, they're not BWF!
Track 1.wav
Track 2.wav
Track 16.wav
Track 1 (2).wav
Track 2 (2).wav
Track 16 (2).wav
Track 1 (3).wav
... and so on
Old December 15th, 2012, 02:42 PM   #2
Re: Multitrack audio import script?
Well, it's not a script but couldn't you sort by file name which would put all of the "Track 1 (xx).wav" files together. Then just select all the track 1's and pull them onto one audio track. Then do the same for Track 2's etc. That might be the fastest way to it since you'd have to go back after as script is finished and check each audio track to make sure the right files got put on the right tracks.
This is a very good example of how a well thought out file control procedure ahead of time really helps the editor. I feel for you as I've been in similar situations.
Garrett Low
www.GLowMediaProductions.com
Old December 15th, 2012, 03:19 PM   #3
Thanks Garret - I think you're right, that would be the most click-efficient method using what Vegas does natively.
I'm going to make a more serious search for a script, though. Lots of places to look. Maybe someone knows of one?
Desired workflow: Select 16 files in the bin. Run a script. In ascending order by file name, those 16 files are now inserted on the timeline at the cursor position, on tracks 1 through 16.
Old December 15th, 2012, 06:34 PM   #4
another way is to rename the files so you can select a group and drop them into audio track 1, then select a second group and drop them into audio track 2, etc thru track 16.
not to hard to write such a script if you're runing windows (being that i'm a techie that cut his teeth on DOS). PM me if you want me to crank out a batch file that does this in windows.
Roberto Diaz is offline   Reply With Quote
Old December 15th, 2012, 07:12 PM   #5
If I understand correctly, the files are already named in sequence, I'm able to do this easily one track at a time. Essentially, I think this is the same method Garrett suggested?
So, with the existing automatically generated filenames from the recorder, I think I'm ready to go for a track at a time. Thanks for the windows batch offer; I'm thinking it isn't needed in this particular case.
Ah, if I could do this across 16 or 24 tracks with a Vegas script...
Old December 16th, 2012, 12:51 AM   #6
You don't need a script if you want to place the selected clips across multiple tracks. Just select the files, and then drag them to the desired position on the timeline with RIGHT mouse button and choose Add Across Tracks command from the context menu
Aleksey Tarasov is offline   Reply With Quote
Old December 17th, 2012, 12:19 PM   #7
Oh, this is very good! Can't wait to try it. So much under the surface of Vegas, even for an old-timer like me.
Thanks Aleksey!
Seth Bloombaum is offline   Reply
