Vegas Pro 15 Update 2 (Build 261) released! - Page 2 at DVinfo.net
Old February 12th, 2018, 02:24 AM   #16
Re: Vegas Pro 15 Update 2 (Build 261) released!
hmmm - I try googling around this issue and found some info...
Try these and see if it works for you:
https://www.vegascreativesoftware.in...9087/#ca605390
Close the program. Now press CTRL+SHIFT while double-clicking on the program's icon to launch it. Continue to hold the CTRL & SHIFT keys until the program is fully up and loaded.
In newer programs, you will see a window that asks "Do you want to reset all preferences to default values?" Place a checkmark next to "Delete all cached application data" and then click Yes.
Here in these links, there are several solutions to try...:
https://forums.creativecow.net/docs/...894213&pview=t
Vegas Pro 13 Stopped Working (Windows 10) "Creating Window" - [Solved] - Windows 10
Hope any of these solutions can help...
Setiawan Kartawidjaja is offline   Reply With Quote
Old February 12th, 2018, 08:07 AM   #17
Thanks! That was the first think I tried, or thought I did. But for some reason I remembered it wrong and was only holding the shift key. I have tried it again now, hold the CTL+SHIFT keys and it did load.
Now I need to figure out how I changed the interface to the original Vegas way (the light background etc), but at least it is working.
So, thank you very much!
Adam
Adam Stanislav is offline   Reply With Quote
Old February 17th, 2018, 01:59 PM   #18
And it happened again. If I have to start from scratch every couple of weeks, this is really PATHETIC. Especially for a software that calls itself Pro.
Old February 18th, 2018, 05:58 PM   #19
try contact support: https://support2.magix.com/customer/en/vegas/form
