Easiest way to Blur out Lisense plates on a moving vehicle? - Page 2 at DVinfo.net
Old January 8th, 2007, 02:14 PM   #16
Sponsor: JET DV
Here's how it works:
Track 1: Normal video with cookie cutter effect
Track 2: Same video with blur added
You get the blur because the cookie cutter effect cuts a "hole" in the normal video allowing the blurred video on track 2 to show through.
Old January 8th, 2007, 05:02 PM   #17
Im still lost, this means you will have to do everthing twice?
Tony Jucin is offline   Reply With Quote
Old January 8th, 2007, 05:22 PM   #18
Ahhh OK! Got it now~!
1 prob. Its really choppy when I playback what is with this? too much to load?
Old January 8th, 2007, 07:51 PM   #19
Sponsor: JET DV
It depends on your computer and your preview level. Once you render, all will be fine.
Old January 9th, 2007, 10:36 AM   #20
could be
bump down to draft quality and if that doesn't help spend 4 hours de-fragging your system. If it still doesn't work, then chances are you system isn't going to be able to preview it.
jason
Jason Robinson is offline   Reply
