Vegas Color Correction at DVinfo.net
Old May 3rd, 2007, 12:27 AM   #1
How do you crush blacks in vegas? Should I use the gamma settings, or is there a better way?
www.wondervisionpictures.com
Conrad Moore is offline   Reply With Quote
Old May 3rd, 2007, 12:48 AM   #2
gamma settings?
do u mean curves?
there are many presets available to download, however curves are what your looking for if u want to crush blacks and blow out the whites
Peter Jefferson is offline   Reply With Quote
Old May 3rd, 2007, 11:59 AM   #3
Yes, gamma curves. Where do I find them in vegas?
Old May 3rd, 2007, 12:07 PM   #4
Jubal 28
Color Curves editor under FX.
David Jimerson is offline   Reply With Quote
Old May 3rd, 2007, 02:15 PM   #5
For a simple tool, there is also the black restore filter (stock Vegas filter).
Old May 3rd, 2007, 02:28 PM   #6
The black restore filter does something else. You probably want to be using color curves.
These curve presets may be useful for studio RGB levels (the default DV and HDV codecs decode to studio RGB levels):
http://glennchan.info/Proofs/forums/...y-presets2.veg
Old May 4th, 2007, 08:04 AM   #7
You can do basic gamma work (and crush noisy blacks to flat zero) with levels, as well.
It's a very easy filter to use.
Matthew Chaboud is offline   Reply
