Is RT.X2 Worth it? - Page 2 at DVinfo.net
Adobe Creative Suite
Old October 25th, 2007, 11:01 PM   #16
Mike, have you played with the new native P2 MXF support in Premiere CS3 as comparred to the added MXF support given by the Matrox Axio LE?
Jim Kunz is offline   Reply With Quote
Old October 26th, 2007, 09:28 AM   #17
Yes, I have used both,and they are very similar. I have actually had better luck with the Adobe version. In my most recent project, Matrox refused to import some of our MXFs that were 1080i60, but the 720p24 worked fine in both. Besides that, I have had few issues with either option. We convert it to MPEG I-Frame 100 for better performance regardless, but the new update allows me to do that without tying up my AXIO system for the conversions. Axio allows AVI reference-type files to be created to give MXF access to other applications. I never re-export to P2, so I can comment on that functionality.
For more information on these topics, check out my tech website at www.hd4pc.com
Mike McCarthy is offline   Reply With Quote
Old October 27th, 2007, 04:13 AM   #18
One of the selling points of the RTX2 is its ability to output HDV to an 'inexpensive flat panel display monitor'. But just how 'inexpensive' is a monitor which has to be 1900x1200 and have DVI in ?
Mike Wade is offline   Reply With Quote
Old October 27th, 2007, 05:22 AM   #19
Hello Mike: I actually checked Newegg, and the 24" Monitors would fit the bill. They only had three, but two were 390.00 and the other was 380.00(all US curr). So pretty cheap to be honest(actually cheaper that I thought myself.. LOL).
I still am using my little analog out television(yes, I know I need to replace it since I am working with HDV, but the little switching I have to do for me is sort of a nonissue) that has been working for me since my X10 days..
Damon Gaskin is offline   Reply With Quote
Old October 27th, 2007, 07:35 PM   #20
Expensive compared to cheap low res computer LCD panels, but very inexpensive compared to other high resolution HD monitoring solutions. The closest solution for other products is to use a $500 SDI-> DVI converter. Luckily the widespread use of HDMI is beginning to change this paradigm.
