HD to SD workflow in CS4 at DVinfo.net
Adobe Creative Suite
Old April 12th, 2009, 12:27 AM   #1
I'm running into a very simple problem that I cannot seem to solve in CS4--I'm working with HD video (filmed on XH-A1 in 60i) and did all my editing in HD. We've exported to vimeo, great quality there. When we downconvert to SD and put it on a DVD, we're running into interlacing problems (i.e jaggedy edges on objects). Here's our workflow--please let me know where the kink is!
Import from camera using Cineform
Edit cineform avi in PP4 project set at 1440x1080, 60i
Do effects in AE using nested sequences
Via dynamic link send to Encore. We've tried to send it as a HD project and then build/burn to DVD. We've tried to send it as a DVD project. We've tried to use Adobe Media Encoder and create mpeg2-DVD.
I've read that you need to send it into AE for best downconverting, but we cannot open our sequence in AE. If I need to export a file in Media Encoder and then open it in AE, what should I export it as/import as/re-render as?
I know that there are a ton of people out there doing this, can anyone tell me the proper workflow?!
Thank you!!!
Jennifer Eidum Zinchuk is offline   Reply With Quote
Old April 12th, 2009, 01:22 AM   #2
Render the MPG directly from AE:
High Definition for PC Downconverting High Definition to DVD
For more information on these topics, check out my tech website at www.hd4pc.com
Mike McCarthy is offline   Reply With Quote
Old April 12th, 2009, 01:46 AM   #3
Thanks for the link. I'm trying to do what it advises, but I want to make sure I do it correctly:
1) export project from PP4 in HD: h.264, NTSC 1440x1080 with upper frames first
2) Put new file into AE and export it as mpeg-2 DVD with lower frames first (as described in the article)
3) Create DVD in Encore
Edited to add:
I checked my footage from step 1--slight jaggedy edges, from step 2--Scary! We tried to export our PPro project directly into AE, but we're getting an unknown error--is that for everyone or unique to us? Can anyone give us clarification for which render settings to use as we export out of PPro?
Thank you! Happy Easter
Last edited by Jennifer Eidum Zinchuk; April 12th, 2009 at 12:54 PM. Reason: Updated to add information
