Merging audio and video at DVinfo.net
Adobe Creative Suite
Old August 8th, 2009, 03:58 AM   #1
Let me say this loud and clear: I'm a VJ primarily and NOT by any means an editor :-) I do news and I can cut a 20 second clip from my takes, and that's about it...
So - once in a while I by mistake selects an export setting in Premiere CS4's media encoder, which results in separate video and audio files (m2v and wav-files).
Times often don't allow for a re-export, so I wondered, if there's a clever little utility on the market that would allow me to join the video and audio to a single file after export. No re-sync is nessesary - just want to join the two "separated children".
Any hints....????
Peter Erfurt is offline   Reply With Quote
Old August 8th, 2009, 04:19 AM   #2
Hi Peter
I doubt unfortunately that any 'utility' out there would be any quicker than simply re-export.
A 20 second clip will render really quickly in CS4.
I use a series of custom settings in Premiere to export depending on whether I want DV, HDV, WMV or Mpeg2 whatever.. Its easy then to call up the preset and export knowing I don't have to go through and set it all up. When in a hurry it is easy to miss a bit or set the wrong settings.
cheers
Gareth
www.gwenllyn.com
Gareth Watkins is offline   Reply With Quote
Old August 8th, 2009, 02:53 PM   #3
Hi Gareth,
Thanks for the reply. I think I will go with your suggestion and create a couple of presets, then.
And you are right - it doesn't take long to re-render my small news clips, but sometimes I first find out about the missing sound after the clip has been transferred to the TV station via Internet - and with an upload speed of 1024 it suddenly takes a lot of time to redo the rendering and upload.
So it would have been nifty, if I just could provide the station with a little "merge-utility" instead ;.)
BUT - I just must learn to check AND doublecheck - or create presets :-)
Kind regards
Peter
Old August 10th, 2009, 02:02 AM   #4
Peter,
All you need to do is to keep multiplexing turned on.
Harm Millaard is offline   Reply
