just moved to Premier Elements - quick questions at DVinfo.net
Adobe Creative Suite
Old June 11th, 2006, 10:23 AM   #1
couldn't get Pinnacle 9.4.3 or 10.5.2 to run on any of my PC's have a deadline, donwloaded Premier Pro & Premier Elements - figured I could use Elements do get this done quick.
I'm trying to do a basic dissolve between 2 clips, and all I wnat is for the video AND audio to dissolve/crossfade. Is there a way to do this, or must I drag a video dissolve and audio crossfade every time?
Also, is there a way to pan & zoom on a still frame inserted into the timeline?
Does Premier have a "Smartsound" like featuer, and how do I use it?
Do any of you know a forum dedicated to Premier?
I'm sorry for all the questions, but I just spent 1 week trying to get Pinnacle (what I am used to) to run without repeatedly crashing, and I give up.
THANKS!
Ed
Ed Langone is offline   Reply With Quote
Old June 11th, 2006, 12:06 PM   #2
The easiest way would be to highlight the clips you want in the Project bin, then go to Project > Automate to Sequence (assuming this is present in Premiere Elements).
If you don't have this, the next easiest method is to put all your clips on the timline snugged up against each other, then place the time bar at the intersection between clips. Press Ctrl+D to place the default video transition (cross dissolve), then Ctrl+Shift+D to place the default audio transition (cross fade). Repeat at each cut. Ta da!
Check out the Motion controls in the Effects pallette. You'll need to learn the basics of key frames if you don't already know about them (check the manual/help file; it's your best friend, believe me). To pan you can also simply click and drag the clip in the Monitor window.
No, you have to purchase SmartSound for Premiere separately.
Right here:
Attend the World Premiere
No need to apologize. The forum is here precisely so that people can help each other.
THANKS!
Ed
You're welcome!
Christopher Lefchik is offline   Reply With Quote
Old June 15th, 2006, 12:37 PM   #3
Hi Ed,
Moved thread into our Premiere forum. post your PP questions in here!
Ed
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline   Reply With Quote
Old June 15th, 2006, 01:30 PM   #4
Ed,
I just noticed I formatted my link to the SmartSound for Premiere page incorrectly. It's been more than twenty-four hours so I am unable to edit my post. Would you be so kind as to fix it?
Old June 16th, 2006, 11:10 AM   #5
There you go chris, no worries.
Cheers,
Ed Smith
Hampshire, UK
Old June 16th, 2006, 01:59 PM   #6
Ed,
Thanks! I usually check my posts, but I obviously didn't that time.
