Way to remove stabilizer noise? - Page 2 at DVinfo.net
All Things Audio
Old September 7th, 2010, 09:31 PM   #16
So here attached is a short first section of the audio with the 70-200 IS stabilizer noise. Sounds kinda like a geiger counter noise.
Nashville TN using Canon 5D MK3, Canon 550D, RODE SVM mic, 70-200 f2.8L II IS, 24-105 f4L IS, 50 and 85 f/1.8, Vegas Pro 11, Zoom H4n, Blackbird, Lilliput Monitor, Lightroom
Harry Simpson is offline   Reply With Quote
Old September 8th, 2010, 11:22 PM   #17
OK, the noise is relatively high frequency, and overlaps the guitar and ambiance fairly heavily... here's my results both with an EQ and a Noise Reduction filter in STP:
Way to remove stabilizer noise?-picture-1.png   Way to remove stabilizer noise?-picture-2.png
Web Youtube Facebook
Cole McDonald is offline   Reply With Quote
Old September 9th, 2010, 07:06 PM   #18
Thanks Cole
James in AZ tried too but the audio is doomed i'm afraid. the client is satisfied with the photographs I got the the video was kind oof a value added thing anyhow.....
1. 70-200 f4L IS is NOISE
2. off camera mic now on if acoustic or interview.....
3. IS off unless really needed while video capturing.......
thanks
Harry
Old September 9th, 2010, 07:25 PM   #19
Hi Cole
I've been talking with Harry via e-mail and I also couldn't get this clean enough to use - I think I had different clips - the one I worked on was fairly long.
Just for the forum record I tried using Izotope's noie reduction and I also got a clean noiseprint (ie just the IS noise by itself when he was just moving the camera around) from Harry and used this to train the Izotope NR. I pretty well got rid of the frying noise, but there was still a lot of other noise in the clip.
I'll post a couple of short excerpts later tonight when I get a little more time.
Old September 9th, 2010, 08:53 PM   #20
I can't help ya on the noise that's on there, but I can suggest the Rycote Lyre type shock mount with is designed for such noises. InVision Video » Rycote
It may not fit the SVM, but for when you get a proper shotgun for outside, or hyper for inside, this will help kill the vibration.
My Work: http://www.youtube.com/ChadWork1
Sony FS5 :: Panasonic GH4 :: Sony PMW-EX1 :: FCPx :: AT4053b :: Rode NTG-3,
Chad Johnson is offline   Reply With Quote
Old September 9th, 2010, 09:04 PM   #21
Crazy thing is - the lens IS is that loud. It's not vibration as much as the motor is loud. The RODE SVM is suspended and all.
Old September 11th, 2010, 04:54 AM   #22
Originally Posted by Harry Simpson View Post
Thanks Cole
thanks
Harry
IS should really be off most of the time anyway, unless you're shooting handheld. Most of the time video would be shot from a tripod and you'd never use stabilization when the camera is on a tripod, either for still work or for video. On a tripod it can actually introduce blur! For handheld, about the only time it really does much to improve sharpness is when your shutter speed is between 1/f and 1/2f where f is the lens focal length. Slower than 1/f it's impossible to get critically sharp even with IS on and faster than 1/2f it doesn't add anything.
Steve House is offline   Reply
