low signal & noise - Sony 44B & Tascam DR-40 - Page 3 at DVinfo.net
All Things Audio
Old April 8th, 2013, 10:38 AM   #31
Re: low signal & noise - Sony 44B & Tascam DR-40
If you're looking for a decent portable preamp to use with your DR-40, the new Roland DUO-CAPTURE EX ($200) is worth looking at. I tried it at Guitar Center and the preamps are very quiet, significantly better than the DR-40.
I decided against it because I wanted a simple integrated solution, but the sound was quite good.
DUO-CAPTURE EX: USB Audio Interface | Roland U.S.
Guy Smith is offline   Reply With Quote
Old April 8th, 2013, 07:10 PM   #32
That may not work so well with the DR40 unless it has nominal +4dB analog outputs. I see what appears to be 1/4" outputs, but Roland does not state op. level or bal/unbal. Likely unbal -10dB for monitor inputs. Otherwise it looks interesting for computer based acquisition.
Old April 9th, 2013, 06:59 AM   #33
Good call, specs list the nominal output level as -6dB.
It seems odd that Roland would choose an output level that is higher than consumer -10dB and lower than professional +4dB.
Old April 28th, 2013, 10:24 PM   #34
Great thread. Lots of info. I too am using a Tascam DR-40 with a Sony ECM-44B. I love it. I run the input gain at about 50% and have the limiter on. The levels are lower than perfect, but I fix that in post. I run it lower to eliminate clipping.
If you looking for an external mixer, have you looked at the Rolls MX54s Promix Plus? I own one because it runs on batteries and didn't break the bank. I've never used it with the Tascam/Sony combo as I've not had a reason to.
Rolls Corporation - Real Sound - Products MX54s Promix Plus
David Peddicord is offline   Reply
