ew 100 g2 transmitter at 100 mw at DVinfo.net
All Things Audio
Old June 12th, 2015, 02:20 PM   #1
anyone of you have ever used a modified ew100 g2 transmitter modified to work at 100 mw?
David Aliperti is offline   Reply With Quote
Old June 12th, 2015, 03:19 PM   #2
Re: ew 100 g2 transmitter at 100 mw
"anyone of you have ever used a modified ew100 g2 transmitter modified to work at 100 mw?"
- No, but according to sources, improvement will be minimal if interference is the issue.
Proper set-up/frequency selection is the key.. especially with a low budget system.
Old June 12th, 2015, 03:51 PM   #3
distance is the issue.
Old June 12th, 2015, 08:43 PM   #4
use the rack mount diversity receiver with external directional antennas. i've made this work at 1500 ft using the stock 30mW transmitter. having a clear frequency is paramount.
Broadcast Audio Mixer / Owner - www.MambaFiber.com
Greg Bellotte is offline   Reply With Quote
Old June 13th, 2015, 01:09 AM   #5
30mW to 100mW is pointless. It will have very, very little impact on range, and for somebody to do it properly needs access to decent test equipment to ensure you don't remove the factory set filtering that allows adjacent channels to function properly. Poorly done gives a rise in output on a meter but can be simply a rise in spurious emissions which you do not want.
Aerials with gain are the successful solution as mentioned above.
Old June 15th, 2015, 01:59 AM   #6
it sounds to me that there is no differences between 100mw transmitters and 30mw transmitters.
Old June 15th, 2015, 02:44 AM   #7
Apart from a VERY short battery life....
Many years ago Sony had a 'linear amp' for their 900mhz radio mics, I asked a sales rep at a trade show what was the battery life when running the amp? His comment 10 minutes, JUST enough for a news cross.
Brian P. Reynolds is offline   Reply With Quote
Old June 15th, 2015, 03:22 AM   #8
To get a noticeable improvement by upping power, 10dB is the often quoted figure - 1W to 10W, or 10W to 100W. 6dB is a very small amount of extra power.
Old June 15th, 2015, 06:19 AM   #9
Upping the power also ups the spurious emissions.
You will get better range by careful positioning of the transmitter and receiver.
If you are using a mains receiver, use the Sennheiser "shark fin" antennas as these have a 3dB boost in reception power.
John Willett - Sound-Link ProAudio and Circle Sound Services
President: Fédération Internationale des Chasseurs de Sons
John Willett is offline   Reply
