New SG35 'Real Spinning Ground Glass Adapter' Commercial version coming soon. - Page 21 at DVinfo.net
Alternative Imaging Methods
Old June 28th, 2006, 07:59 AM   #301
Ah the music. Excellent. And the footage very nice.
Isn't that an M35 rig? Or Micro35? From Redrock?
I guess I'm wondering if the SGpro is just a part of another 35mm adapter rig that you use. I can't see on the rig photo where the SGpro is. Am I blind or just confused.
David
www.motivitypictures.com
David Eggerichs is offline   Reply With Quote
Old June 28th, 2006, 08:04 AM   #302
Hello,
The SGpro is the Box with the lens attached, and also the rails, clamps and sliding plate.
If you visit my webpage in my sig, you will find more info on the SGpro.
Wayne.
Wayne Kinney is offline   Reply With Quote
Old June 28th, 2006, 08:06 AM   #303
Originally Posted by Wayne Kinney
i know he has a 16mm Nikon. I'll see if he can shoot something.
Wow, 16mm is really something, thanks in advance!
Frank Hool is offline   Reply With Quote
Old June 28th, 2006, 09:34 AM   #304
Nice one wayne, one of the best samples i've seen so far. Doesn't look like there was much light loss either. I just hope the glass is HD worthy.
Yasser Kassana is offline   Reply With Quote
Old June 28th, 2006, 12:39 PM   #305
With the SGpro, how many stops of light do you lose and does it flip the image for you?
Amos Kim is offline   Reply With Quote
Old June 28th, 2006, 01:06 PM   #306
Hi,
The light loss is about 1 stop, and it does not flip the image, the image recorded to tape is rotated 180 degrees and needs to be rotated back in post.
Wayne.
Old June 28th, 2006, 02:11 PM   #307
is there any image degradation, noise? and how much is this adapter? I'm looking for an adapter and I keep hearing m2 as the one to get. thanks
Old August 8th, 2006, 04:41 AM   #308
SGpro's Interchangeable Mounts
Hello guys,
I thought while I had a selection of different lens mounts here at 1 time, I would take some pictures of them to show you guys. In the image from the left is an M42, Canon FD, Nikon F and Canon EOS mount, all aluminium machined. You can see in the picture, the difference in register/flange focal between is actually machined into the mount itself.
http://www.sgpro.co.uk/SGpro_mounts.jpg
Also have a picture here of a test PL mount on the SGpro:
http://www.sgpro.co.uk/pages/gallery...5-1503_IMG.jpg
Below is a list of available mounts:
Canon FD
Canon EOS/EF
M42
Contax
Leica R
Leica M39 Screwmount
Minolta MD
Nikon F
Olympus OM
Pentax K
PL mount
Please let me know what you guys think.
Wayne.
Old August 8th, 2006, 07:38 AM   #309
Nice to see! Now I've placed my SGpro order, I'm even more curious about what other lenses I could be using with all the mounts you have available.
PL mount lenses appear to be quite expensive. How different would the overall look be compared to a decent standard SLR lens?
Glenn Thomas is offline   Reply With Quote
Old August 8th, 2006, 07:48 AM   #310
Great question, but I know their or more qualified people on this board that can better answer this question. Im sure a set or arri or cooke lenses are going to be sharper then any still lens. They are also designed for the moving image, so no breathing on focus racking...
Wayne.
Old August 8th, 2006, 08:51 AM   #311
Interesting point. I believe they're also much better designed for focus pulling.
Old December 12th, 2006, 01:47 PM   #312
Adapter Optics clearout - achromats and condenser lenses - new
Hello guys,
Over the past year I have acumalated alot of stock of lenses for adapters from test that are brand new, unused. I thought it was time to have a clearout and sell off some of the lenses I simply wont be using. I thought it would be nice to offer the lenses at a cut down price to you guys so you can use them in your DIY adapters/projects. Below is a list of whats on offer:
10x SGpro R2 achromats (yes, the current version!), just the lens, no threaded ring, 10x surplus - £60 each (get it while you can)
3x Glass aspherical condensers (as was used in the SGpro) - 64.1mm dia, 85mm focal length: £10 each
4x Glass DCX condenser - 52mm dia, 78mm focal length - £10 each
2x DCX/BCX condenser lens, anti reflection coated - 50mm dia, 112mm focal length - £10 each
10x Achromat, anti reflection coated - 51mm dia, 182mm focal length - £15 each
10x Achromat, anti reflection coated - 40mm dia, 156mm focal length - £12 each Great for 43mm thread cams or lower#
Please email me at info@sgpro.co.uk if interested.
Wayne.
Old December 14th, 2006, 03:05 PM   #313
I have also got some ground glass of various finishes:
Ground glass:
400 grit: 38x26mm - great bokeh. Good for a vibrating/ocsalating design but has larger grain. £15 each
600 grit: 38x26mm - less lightloss, great for a vibrating/ocsalating design. £15 each
1000 grit: 38x26mm - very low lightloss, great for a vibrating/ocsalating design or even a static design. £15 each
Wayne.
Old December 16th, 2006, 01:36 AM   #314
I have sent you e-mail before but you never replied me.
Lau Ho Ming is offline   Reply With Quote
Old December 16th, 2006, 03:15 AM   #315
what is the exact size and diopter of the sgpro r2 achromat?
