HD-Out over HDMI while recording - Page 3 at DVinfo.net
Canon EOS Crop Sensor for HD
Old March 1st, 2010, 07:35 PM   #31
I have an Acer 23" monitor and it's great for a computer monitor and for reviewing clips from the camera. However, you can't use it as a monitor when recording on all Canon DvSLRs. It doesn't switch to 480 mode and locks up the 5D2.
Jon Fairhurst
Old March 1st, 2010, 07:43 PM   #32
Interesting. I wonder which or how many other monitors suffer from that issue.
Current cameras: Canon EOS Digital Rebel T2i (coming soon) | Panasonic LUMIX DMC-GH1 | Sony HDR-SR11 (infrared modded)
Fei Meng is offline   Reply With Quote
Old March 2nd, 2010, 03:50 AM   #33
Originally Posted by Robert Turchick View Post
... bit of a disappointment but still very useable.
You think also usefull for follow focus things?
PS: I think if you set the camera on pal it will output a 576p signal.
Daniel
Daniel von Euw is offline   Reply With Quote
Old March 2nd, 2010, 08:52 AM   #34
"PS: I think if you set the camera on pal it will output a 576p signal."
i wish it could record in 720x576 (16x9).
Emil Gustafsson Ryderup is offline   Reply With Quote
Old March 2nd, 2010, 02:19 PM   #35
Can you have an external monitor and the LCD-display running at the same time? One for the operator and one for the focus puller?
Old March 2nd, 2010, 02:27 PM   #36
No. The camera's LCD display panel is automatically turned off when cabling out via A/V or HDMI. There is no way around this that I'm aware of.
Old March 2nd, 2010, 02:37 PM   #37
I had a similar thing happen with my HMC-150, needed to output to two monitors and the HDMI and component outs cancel each other. I got around this using an HDMI splitter from Kanex for $80. You will be locked into sending the 480p to both monitors though.
Old March 2nd, 2010, 02:38 PM   #38
Yes I think it's fine for follow focus.
Old March 3rd, 2010, 10:46 AM   #39
just tested my friends T2I - connected it to my LCD (PC) monitor via HDMI, and my monitor kept flashing black, then blue when I hit record (doesn't do this with 7D). I can only assume that it's doing this because it doesn't support the low resolution output of T2I (when recording). So under that assumption, I connected it to my SmallHD monitor - it worked, but at a very low resolution.
Much more difficult to determine focus IMO. I think most T2I users are better off pulling focus with the camera's LCD.
Randall Rodriguez is offline   Reply With Quote
Old March 3rd, 2010, 01:27 PM   #40
Here's some interesting info:
Canon T2i/550D HDMI Output Footages
[T2i/550D] [17-55 IS USM] [Zoom H2] [HoodLoupe/HoodMAG 3.0]
Stan Chase is offline   Reply With Quote
Old March 3rd, 2010, 02:09 PM   #41
Compare these two images (click to embiggen). The first is the live HDMI output. Hopefully you can see how it's slightly windowed, plus there's the red recording icon. The second is the actual HDMI playback, which fills the screen as you'd expect. The overall wonkiness is due to the wide-angle lens of my little point & shoot digicam.
HD-Out over HDMI while recording-hdmi1.jpg   HD-Out over HDMI while recording-hdmi2.jpg
Old March 21st, 2010, 01:34 AM   #42
Still, do you guys think there's a big chance a Magic Lantern hack for the T2i will emerge soon and enables HD-output during record?
Michiel van Baasbank is offline   Reply With Quote
Old March 21st, 2010, 12:48 PM   #43
It won't be soon. Tramm is focusing 100% on the new 5D2 2.0.4 firmware. After that, I believe that the 7D would be the next most likely. I have no idea if he even has a 550D/T2i right now, though he does have a 7D.
Jon Fairhurst
Old June 21st, 2010, 01:22 AM   #44
Yeah, I can confirm this. My Acer 23" does not play nice with my T2i via Mini-HDMI. When I hit record on the camera the monitor goes blank and the camera freezes up. Nothing is recorded.
"Who's scruffy lookin'?"
http://www.amfproductions.com
Bryan Harley is offline   Reply With Quote
Old June 21st, 2010, 07:17 AM   #45
First post and someone who is about to buy a 550d, this thread made me curious.
Is there any reason that you cannot capture the 1080i live view output?
edit: one more related question, is there any possible way of viewing the 550d hdmi output wirelessly? ie if its running along a cable or attached to an RC helicopter?
Sam Tansey is offline   Reply
