550 as B-cam? - Page 2 at DVinfo.net
Canon EOS Crop Sensor for HD
Old May 12th, 2010, 03:49 PM   #16
I would be more eager to use my 550D (PAL) more often if I could execute even the slowest pan with it. As soon as you move the camera, even on a heavy fluid tripod, the jitters set in. It is impossible to pan the camera, even very slowly without ending up with an unusable shot. If I change the video system to NTSC the jitters completly dissapear? what have Canon done with the PAL cameras. The jitters are there on the cameras LCD, and when played back via HDMI, change to NTSC and shoot @30 or 60 and I get perfect footage. A friend with a 7D has the same problem??????!!!!!!!!!!!!!!!
Colin
Colin Rowe is offline   Reply With Quote
Old May 12th, 2010, 04:37 PM   #17
No jitter here. Even on fast pans.
My Films My Works FB
George Angeludis is offline   Reply With Quote
Old June 9th, 2010, 11:15 AM   #18
Originally Posted by Robert Turchick View Post
At this point, the DSLR's should be used a B-cams unless you can work around the 12 minute record limit and overheating.
Is the 12 minutes limit due to the size of the card or the FAT format?
Will the T2i stop recording even if you use a larger card?
Ervin Farkas
www.AtlantaLegalVideo.com
Old June 9th, 2010, 11:40 AM   #19
Originally Posted by Marc Faletti View Post
Whenever I use my T2i with an EX1, I only wind up keeping the audio from the EX1. It's nice to have the safety of the EX1 image just in case, and I would never use the T2i in run-and-gun situations (other than maybe weddings), but the more control you have over shooting environments, the more a DSLR can be your primary weapon (with separate audio recording).
Are yoiu kidding??? The EX1 wipes out the Canon DSLRs for image quality, and it doesn't come with any of the monstrous spacial aliasing or moire problems, that the Canons have. I use both, so it not a biased observation.
Colin
Old June 9th, 2010, 11:45 AM   #20
Its nothing to do with the size of card or file system. It is an EU tax ruling. Doesn't matter what card size you use, it will stop at 4gb, approx 12 minutes at max resolution.
Colin
Old June 9th, 2010, 11:53 AM   #21
Aha.
But I'm on the other side of the Pond... so what about the US version [if there is one]?
Ervin Farkas
Ervin Farkas is offline   Reply
