what's the best way to monitor audio? at DVinfo.net
Canon EOS Crop Sensor for HD
Old December 10th, 2010, 07:37 AM   #1
When not using a Zoom recorder or the like how can I go about monitoring audio? I can control the line level of a mic going into the camera but how do I monitor it on the fly?
I was thinking I can use the A/V output to an RCA-1/4" adapter but then I would have to hook my monitor up with RCA instead of HDMI and lose a lot of my video monitoring ability.
Is there a solution?
Jon Bickford, Trepany Films
San Pedro, CA
Trephine001@aol.com
Jon Bickford is offline   Reply With Quote
Old December 10th, 2010, 04:43 PM   #2
Contributor
That's about it. If you're using a Juicedlink or some other device to defeat the auto gain, it probably has a headphone out jack, but you're only monitoring what's coming to it, not what the camera is really getting. I've started recording some of my audio to my 5D since it can now do manual gain, but I always double record to the Zoom. I use a Y-adapter from the Zoom's output, with a pad cable to take it to mic level for the camera and calibrate the camera's meters so it's matching the zoom. So I know the audio going to and coming out of the Zoom is good, but there's no easy way to tell what the camera is doing till after the fact. So far it's been fine, but what if the cable dies or something like that? So double recording is the only safe way. And the Zoom quality is better anyway. I find the camera sound acceptable for somethings, but not for something that might be shown with theatrical sound.
If you can use a monitor and go that route then it's the safest for camera sound.
Old December 12th, 2010, 12:45 AM   #3
this is how i do it.
J.J. Kim is offline   Reply With Quote
Old December 12th, 2010, 08:18 AM   #4
J.J.
that is the exact way I'm going to monitor audio and record on my 7D, I just got the cables last week (have not tried it yet, but I guess it works after viewing your video). I got the Zoom H2 coz most of my mics got 3.5mm stereojack, so I didn't se a point geting the more expencive H4.
thanks for sharing
/Markus
edit:
The only thing that I've been thinking of is if the audio signal gets weaker if you split it?
Markus Nord is offline   Reply With Quote
Old December 12th, 2010, 04:44 PM   #5
I personally use a 3.5mm to bluetooth dongle, and wireless bluetooth headset, connected to my h4n zoom.
Jonny Norquist is offline   Reply With Quote
