Continuous recording with T2i.. at DVinfo.net
Canon EOS Crop Sensor for HD
Old January 21st, 2012, 10:15 AM   #1
OK, so magic lantern allows recording to restart automatically once a clip reaches its max and stops. However, how long could you let it run like that? How does the T2i do as far as overheating? If I wanted to have one shooting a continuous wide shot during a wedding unattended could I do that without the camera shutting down? I am aware that I lose a couple of seconds between recordings.
Brad Ballew is offline   Reply With Quote
Old January 21st, 2012, 11:31 AM   #2
Re: Continuous recording with T2i..
I haven't done any rigorous testing to confirm this, but I believe the overheating problem is reduced when a battery grip is used. My T2i used to overheat fairly frequently until I got a grip, and it hasn't overheated since.
Jon Onstot is offline   Reply With Quote
Old January 21st, 2012, 12:10 PM   #3
Yea, you can use a battery grip, but you can also turn the bit rate down and turn the lcd screen off during recording. These are things that I have found to help out with overheating. Since it will be unmanned, there is no need to have the lcd run during recording. Every time I do this, this will almost certainly make sure that it doesn't overheat. These are both options you can achieve with magic lantern!
Keith Betters is offline   Reply With Quote
Old January 21st, 2012, 12:27 PM   #4
Thank you very much for the responses. A battery grip would probably be a good idea anyway if I am going to attempt that type of shooting.
Old January 22nd, 2012, 01:25 PM   #5
Similar to turning off lcd. I found that using a monitor also helped with the overheating.
Donald McPherson is offline   Reply With Quote
Old January 23rd, 2012, 01:01 PM   #6
I use a 550d/t2i with the 11-16 tokina as a c cam at almost all af my weddings ( wide cam on rear balcony)
Using magic lantern, battery grip and a 32gb card (class 10, in my tests class 6 cards had issues)
The memory card fills up before the battery(s) run out, and that's without any power saving options from magic lantern. ( which is about 90 mins worth of 12 minute clips )
Done this for about 50 weddings , never had any issues (touch wood)
I also use loads of the other features that magic lantern provide, magic zoom, WB Kelvin to name 2.
James Strange is offline   Reply With Quote
Old January 25th, 2012, 11:59 PM   #7
battery grips, on-board, LCD off, monitor over HDMI (on main camera), and i have never had an overheat warning. Sandisk 8/16GB Class 10.
Panagiotis Raris is offline   Reply With Quote
Old January 26th, 2012, 12:13 PM   #8
Battery grip +1. It increases the time before T2i got overheated. Also, good for doubling the run time. Also turning off the LCD screen does have an impact too. I put together some test on T2i to see how long it started to show the overheat icon.
Canon T2i Overheat Test | L.A. Color Blog
LA Color Pros Blog
Old January 29th, 2012, 04:40 AM   #9
Another time I was handholding the camera and it seemed to overheat very quickly. Must be my hot hands.
Old February 1st, 2012, 12:00 PM   #10
I feel like an idiot. I cannot figure out how to turn off the LCD screen during recording. Is this an option in Magic Lantern? I am not seeing an option for it. I will keep looking, but if someone could enlighten me, it would be much appreciated.
EDIT: Never mind just figured it out.
