HDVSplit -> AE -> Microcosm -> Avid at DVinfo.net
Old May 21st, 2007, 03:12 PM   #1
I’m learning about HDV 24p.
I have After Effects 7 and Avid Xpress Pro HD 5.2.4(Cant upgrade Avid because of current system limitations).
I am thinking my workflow should be:
•Digitize w/ HDVSplit
•Perform 3:2 pulldown using AE 7
•Export from AE7 with the Microcosm codec
•Import into Avid for editing
Does this look correct?
Would anyone do anything different?
Rastus
Rastus Washington is offline   Reply With Quote
Old May 21st, 2007, 06:13 PM   #2
Hi,
I have been using a method using free tools developed by few people in this and other forums. The method is HDVsplit->Steve's tool -> avi file -> NLE.
Steve's tool is a self-executable file (needs .NET though) which uses
1) Avisynth,
2) DGIndex
3) VirtualDubMod
Its described in detail in this thread. (http://www.dvinfo.net/conf/showthread.php?t=94235).
The thread title is a bit confusing because steve initially developed this as a Vegas Script.
I did try using AE (trial version) but output seems worser than Steve's (can be due to codec choice). You might give it a try though.
Ajit B.
Ajit Bikram is offline   Reply With Quote
Old May 23rd, 2007, 04:37 PM   #3
I'll try those.
Rastus
Old May 23rd, 2007, 07:31 PM   #4
I edit on Avid also and what I recently found to work well is use MPEG Stream Clip (freeware) to remove pulldown and export as a QT in the DNxHD 175 codec. Then, you can edit in a true 1080p24 HD project.
AE is fine, but it is extremely slow.
I have HDVsplit but haven't used it for capture, but that would work fine (I've been working with Console, so no tape).
EDIT: I use Console for my A1 footage, not my HV20. But MPEG Stream Clip works well for either.
Mainly dabble in features and WebTV:
www.pinktheseries.com | www.facebook.com/continuumtv | www.killingdown.com
Blake Calhoun is offline   Reply
