XH-A1 went dead. at DVinfo.net
Old November 1st, 2008, 11:45 PM   #1
XH-A1 went dead.
Is there a reset, or anything I can try to get the XH-A1 to come on, battery is fine, works in my other A1, it came on when I went to capture then just went dead, no life showing at all.
Denny
2 Canon XF305's
Kyser Photography www.kyserphoto.com
Denny Kyser is offline   Reply With Quote
Old November 1st, 2008, 11:54 PM   #2
Denny there is a reset under the lcd screen it is a small hole but whether it will sort your camera problem I don't know.
Alan
Alan Craig is offline   Reply With Quote
Old November 2nd, 2008, 03:03 AM   #3
Hi Denny. Have you checked the Standby/Lock switch beside the Start/Stop button? If it is slightly out of position the camera will appear to be dead.
Richard
Richard Hunter is offline   Reply With Quote
Old November 2nd, 2008, 06:56 AM   #4
Tried both of those, but no luck looks like it will have to go back to canon, luckily its exactly 11 months old, I hope the turn around time is good.
2 Canon XF305's
Old November 2nd, 2008, 07:44 AM   #5
Before you send it anywhere, you might want to polish up the contacts within the battery compartment. Some schmutz might have gotten in there.
I've not heard of this happening, but it's worth checking before you ship it off.
Old November 2nd, 2008, 03:08 PM   #6
Hi
Does it start in VCR mode?
/Bo
Bo Sundvall is offline   Reply With Quote
Old November 2nd, 2008, 04:41 PM   #7
Go Cycle
Did you use OTHER than CANON batteries?
Does your AC power-supply work?
If not, sounds like you burnt out your power board.
Lou Bruno
Lou Bruno is offline   Reply
