Frame Rate Advice - Page 2 at DVinfo.net
Old January 24th, 2009, 07:26 PM   #16
Originally Posted by Tripp Woelfel View Post
Vimeo has supported 30p for about eight or nine months. I new that 25p was in the offing for the PAL folks.
Before they supported 30p if you uploaded a 30p video, in the transcode to flash it would unceremoniously drop the last six frames each second. It wasn't just herky-jerky. It was spastic.
Tripp, are you saying that Vimeo plays back clips at 30P, or that the frame rate conversion is better now? The mods seem to think that it doesn't play 30P.
Richard
Richard Hunter is offline   Reply With Quote
Old January 25th, 2009, 02:22 PM   #17
i record rollerblading, shoot in 60i, at a variable of different shutter speeds, (am i correct in saying the higher shutter speed also helps in the quality of slow motion?)
i do de-interlace to either odd or even (FCP)
after all this, does the frame rate become 30p??
~thanks
Janson Williams is offline   Reply With Quote
Old January 28th, 2009, 02:20 AM   #18
so wait...if i shoot 24f (on Canon XHA1), should i deinterlace at all during any process of editing, or no?
Chris Light is offline   Reply With Quote
Old January 28th, 2009, 03:08 AM   #19
You should never need to deinterlace progressive footage. In fact it is likely to introduce artifacts and make the image quality worse. Try to stay progressive all the way, i.e. make sure clips, project and output render are all set to progressive.
Richard
Old January 28th, 2009, 07:37 AM   #20
I'm not privy to the inner workings of Vimeo, but as I understand it there is no frame rate conversion for 30p or 24p video. I've heard that 25p is or will soon be supported.
Any stuttering you see in a video is probably due to dropped frames. Depending upon the video you're watching, the dropped frames could be in the source video and not part of the transmission process.
Old January 28th, 2009, 04:52 PM   #21
Hi Tripp. Dropped frames? I don't know why you would say that, it seems very unlikely, especially when the uploaded video plays OK and the stuttering only happens after the Vimeo conversion process. BTW I haven't seen dropped frames in years (and I'm still using tape most of the time).
Richard
