HDV/SD downcovert doesn't work? at DVinfo.net
Old December 16th, 2006, 11:06 AM   #1
recorded some HDV footage. Go to VCR/play position, select "signal setup" and HD down-conv is grayed out. I'm trying to play out via the firewire port to my DV deck/edit sys. Tried powering down then up, no luck.
Anyone have a clue?
David Morgan is offline   Reply With Quote
Old December 16th, 2006, 11:14 AM   #2
answered my own question
The firewire cable has to be DISCONNECTED from the camera in order to select the HD downconvert setting.
Old December 16th, 2006, 12:04 PM   #3
same action tried few minutes ago...
yes, disconnecting the firewire cable puts the gray one option, in a selectable state.
In addition I can say that I down-converted a 25F footage (I work with the PAL version), using a DV PAL Anamorphic set up in FCP and it was perfect!
Stefano Folgaria is offline   Reply With Quote
Old December 16th, 2006, 07:27 PM   #4
anyone using Premeir Pro 2.0 or After Effects 7.0 have a good workflow to take HDV and downconvert into a 4:3 file for eventual dub to Beta SP for TV submission?
Lyon Films www.LyonFilms.com;
Devon Lyon is offline   Reply
