XL-H1 viewfinder problem
My XLh1 was on a shoot yesterday (someone else using it)....and the viewfinder "all of a sudden" got really dark. The recorded image was fine, it was just a viewfinder issue. I know the cameraman who was using it likes to explore gear and push lots of buttons, so I searched through all the menus...nothing looks out of place. So, has anyone ever seen this happen before? Did something in the viewfinder blow out?
I quickly searched the interwebs for a replacement, but it looks like the only one you can get is the B&W version...any advice would be appreciated. thnx |
Re: XL-H1 viewfinder problem
Sometimes the most obvious issues get overlooked; so just in case have you tried unplugging the viewfinder and replugging it in (when the unit is off)?
http://vimeo.com/channels/guerrillafilms |
yup, tried that.
I have a feeling the viewfinder was unplugged while it was on, could that have messed something up? Camera man was looking to unplug the onboard mic and pulled the viewfinder plug instead. |
That could be it, but I've haven't actually heard of that specific problem before.
I had heard that the XLH1 was prone to blown fuses if you messed with the firewire port or changed lenses while it was on. For that reason I always shut it off before I changed any cables or lenses.
#5 |
Those fuses aren't accessible, are they? I'm guessing that means a trip to canon.
#6 |
So it's still 'dark' ? Try a reset before you send it in. Check your manual.
Cheers.
Support your local movie theatre, they need it. |
#7 |
Yup....still dark. Allan, what reset are you referring to? (just checked the manual, I don't see any reset instructions).
#8 |
Mike, I don't have a H1 but the Canon XH-A1 and A1s both have reset buttons on top of the cam under the foldout EVF and instructions in the manual saying how to activate it. So I assume the H1 has one.. ? HTH
Cheers.
#9 |
ok, found the reset button (had to do a search through the PDF manual, because it's not in the index)....pressed it for 10 seconds....and....still dark.
#10 |
My instructions say to power the cam with AC not battery and make a list of all my custom settings because they'll be deleted with a camera reset.
Just a thought, your H1 is not on auto with the iris closed down? No? .. oh well Plan B off to the shop. Cheers.
