JVC Fujinon 16x v. Canon Manual 16x XL at DVinfo.net
Old January 5th, 2007, 10:03 PM   #1
Has anyone done a side by side comparison of these two lenses? Which has the sharper glass, weight, breath, etc.
I wonder how sharp an XL H1 w/ the 16x manual compares to JVC's stock Fujinon lens.
R.W. Swanson is offline   Reply With Quote
Old January 6th, 2007, 03:02 AM   #2
I've owned both the Canon Manual Servo 16X lens and the old 14X Fujinon Manual lens (same one that comes with the older JVC GY-DV500U and Pansonic AJ-D215 bodies and professionally converted to Canon XL bayonet by Optex) and it would be hard to spot footage shot with both, although the Fujinon is slightly softer at the extreme wide setting. However, if pushed I would give the nod towards the Canon, not only for the slightly better image quality, but more so for the much superior handling (even though the Fujinon is much smaller and lighter than the 16X Manual, and even lighter than the Canon 14X Manual).
The 16X Canon Manual Servo is a lovely lens to use.
The Fujinon 16X HD lens packed with the JVC GY-HD100U I haven't tried, and I would expect be an improvment on the older SD 14X Fujinon, although I've still heard a lot of reports of some softness at the wide end (Will Holloway in his review, for example, sites the 16X Fujinon lens on the GY-Hd100U as having soft edges).
The much more expensive Fujinon 13X lens has received much better reports with sharp images throughout the frame.(It would be interesting to view a comaprison between the new Canon XL 6X HD lens and the Fujinon 13X lens).
www.WILDCARP.com
www.NIKON.me.uk
Tony Davies-Patrick is offline   Reply
