#91 |
Bob, the flashing CP2 message indicates that you have selected Custom Preset #2 but it has not been activated. Press the Custom Preset Select Switch (second button from bottom behind red sliding door) to select the desired preset or to turn presets off completely. Use the Custom Preset On/Off switch (bottom button behind red sliding door) to activate the selected preset. This is explained on page 70 in the NTSC manual but I don't know about the PAL version.
Ed Frazier |
#92 |
CP2 Flashing Fixed
Thanks Ed.
It was in the PAL manual (Page 68). Those cycling menus get me all the time. Thanks again. Bob Glover
Bob Glover Perth Western Australia |
#93 |
Black Bars in viewfinder
I was wondering if there was an option on either the XL-1 or XL-1S to see the black bars on the top and bottom when shooting in 16:9 mode. Right now it just stretches it. Thanks.
#94 |
Retired DV Info Net Almunus
Nope. Sorry.
Lady X Films: A lady with a boring wardrobe...and a global mission. Hey, you don't have enough stuff! Buy with confidence from our sponsors. Hand-picked as the best in the business...Really! See some of my work one frame at a time: www.KenTanaka.com |
#95 |
Get an external monitor that has a Vertical hold knob.
Then you can compress the picture on the monitor and it should look normal and have black bars on top and bottom |
#96 |
ya, I have a monitor that has underscan button that allows me to do that, but for some reason I thought there was an option to do it in the viewfinder. Thanks though.
#97 |
Rigging an external monitor through viewfinder out.
What exactly would it take to rig an external monitor through the viewfinder out? Im thinking if I could find the cable used for the viewfinder, then I could experiment with riggin it up. I would very much like to avoid using a viewfinder, as I rarely do run and gun stuff, but I would like to be able to get the zebras on screen. Any input would be awesome.
Stephen |
#98 |
RED Code Chef
Information on the pin-layout can be found here
Be careful if you are going to make cables etc. yourself!
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#99 |
thanks, ill get to work. Im not sure ill be able to do anything with it, but that is more than I was expecting to get.
Stephen |
#100 |
Where did he get the cable? Is it possible to get it from Canon, or is it a standard?
Stephen |
#101 | |
RED Code Chef
Quote from the actual article:
#102 |
I found the part. If anyone is interested it is the CVF Cable Assembly part #dg12924 and it costs 31.56. You can order it at 732-521-7230.
Stephen |
#103 |
One thing I did not research when I did the article is the output impedance and levels of the signals at the CVF jack. Depending on what you are trying to drive, you may need to buffer them.
dpalomaki@dspalomaki.com |
#104 |
Moderator
Has anyone actually successfully rigged an external display via the 6-pin EVF output? I would like to see pictures if possible, as I am very interested. Also, has anybody succesfully utilized the RGB out from the 6-pin EVF output? Again, I would love to know!
- don
DONALD BERUBE - noisybrain. Productions, LLC Director Of Photography/ Producer/ Consultant http://noisybrain.com/donbio.html CREATE and NETWORK with http://www.bosfcpug.org and also http://fcpugnetwork.org |
#105 |
Note that the RBG output of the EVF jack is not the video image; it is the various icons (and probably messages) that overlay the image in the EVF.
| Thread Tools | Search this Thread |
