#1456 |
Retired DV Info Net Almunus
Welcome Anne.
Sorry to hear of your trouble. You must be pretty disappointed with your new camera. Unfortunately, this is clearly a manufacturing defect that you will not be able to fix for yourself. Send the camera to Canon Service as soon as possible, as it's still covered by warranty.
Lady X Films: A lady with a boring wardrobe...and a global mission. Hey, you don't have enough stuff! Buy with confidence from our sponsors. Hand-picked as the best in the business...Really! See some of my work one frame at a time: www.KenTanaka.com |
#1457 |
This should be a warranty repair in my opinion.
One quick note, sometimes problems like this can be caused inadvertantly by operator error (although please understand that I'm not at all claiming that this was the case here). The lens has a series of contacts along the back plate that connects to the camera head. If the camera is not switched off prior to removing the lens, then it's possible for those contacts to cross-connect around each other with power going through them during the act of removing a lens or putting one on. It's possible to short out some cicuitry that way. This is why it's crucial to power the camera down when changing lenses. Regardless of the particular cause in this case, whether it's a manufacturing defect or operator error, it should be repaired free under warranty. Please let us know how it goes. |
#1458 |
The stop-to-stop zoom speeds of the ZR-1000 are contained in an article on this site at:
http://www.dvinfo.net/canon/articles/article63.php Thera also are reviews of sevaral of the VariZoom products among the articles.
dpalomaki@dspalomaki.com |
#1459 |
The plugs are standard sizes (available even at Radio Shack), but the combination is unique to Canon, and has been since the L1/L2 days. The 3.5mm stereo plug is for the audio and carries the ground and audio output from the mic, and the 2.5 mm mono plug provides power to the mic.
#1460 |
The XDA-4C should be a passive device - meaning no amplifiers in it and thus nothing to generate noise, except perhaps for an open ground or pickup of stray electrical/magnetic fields in the area.
Is this a long-standing problem or has it just started? Have you tried the Beachtek on a different camcorder? What else is connected to the camcorder? What is the noise level and does the manual gain control effect the noise level? How are you powering the XL1? If batteries, what brand and rating? Old or new? Try different batteries and A/C power - see if that makes a difference. I suggest this because I've noticed when using the MA100 that under some circumstances different batteries can induce a very low level, high pitched noise in the system. While the Beachtek is a different device, there might be something similar going on.
#1461 |
broken white door on camera
The door over the audio knobs on the back left of the Xl1 broke in a recent accident. I ordered the new part from Canon, however it appears that this is much more than just the door itself. The door and hinge is attached to the white piece of plastic that makes up the majority of the left side body of the camera.
Has anyone ever replaced this part before? How do you get that off to fix it? Thanks! |
#1462 |
Not recommended for the non-technician. It appears to be held on by a screw or two from the inside of the frame. A significant undertaking.
#1463 |
Canon XL FLANGE FOCAL DISTANCE
Hallo,
some one know the exact FLANGE FOCAL DISTANCE on the canon XL mount ??? thanks PR "sorry for my poor english"
http://paolorudelli.lickthetoad.org |
#1464 |
XL1s Zeba pattern/ and broadcast safe
Hello folks and thanks so much for being out there. My question is When shooting with a XL1s you can set the Zebra pattern to show areas of overexposure with the settings of 80-95. I am trying to aquire video that will be broadcast safe (whites under 100) to save time in the editing process. While shooting recently I had my camera hooked up to a NTSC field monitor to get an acurate idea of picture quality. The image in the viewfinder looked a little milky as I stopped down to reduce Zebra in hot spots but looked fine on monitor. I used monitor for referance. I need information on how to set up XL1s to get the best quality picture for TV broadcast.I have not been able to find information on the operation of the camera in reguard to broadcast levels. Any good reference materials would be helpful.
thanks, Brian
Brian |
#1465 |
Broadcast save video signals involve luma and chroma combined levels. Unless you have a specific control monitor, like e.g. Barco's (today Scientific Atlanta) CVM 3000 monitor you cannot estimate on a monitor whether or not the signals are legal. If you keep the combined (composite) signal level below 120 IRE on a waveform monitor you will be safe
#1466 |
Eject does not work
The outer door will open but can not load tape . The carriage will not budge. No tape in camera.
Thanks Tony B xl1-s |
#1467 |
You must send this camera in for service right away.
Canon Factory Service 100 Jamesburg Road Jamesburg, NJ 08831 tel: (732) 521-7007 |
#1468 |
RED Code Chef
I think you need a service manual for that kind of information. I
don't think it has been discussed here before to that extend.
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#1469 |
XLR Cable Length for XL1S/MA-100
I wish to use the Sennheiser ME-66 mounted to my XL1S (on a Lightwave MM-XL) connected to an MA-100. How long an XLR cable should I buy for this configuration? I imagine it will be fairly short.
#1470 |
XL1S Original Mic Cable!? Help!
Anyone knows where can I get just a cable (with two plugs) that connect original microphone with XL1S body? Inside the XL1S mic, cable is connected via small connector so I guess it is possible to change whole cable. Or is it only solution for me to buy another XL1S mic? Anyone knows where?
Please help!
poiu |
| Thread Tools | Search this Thread |
