Change UK plug on charger to US plug? at DVinfo.net
Old October 16th, 2001, 04:11 AM   #1
Peter Kingsbury
Posts: n/a
I live in the US. I just bought the PAL version of the XL-1s which came from the UK. The plug on the CA-910 power adaptor is, of course, for the UK. I've read in the manual that the CA-910 charger can be used anywhere in the world at 100-240 volts (50-60 Hz). It also says this on the power adaptor's label. Does anyone know if one can simply replace the UK plug on the cable with a US plug?
Thanks for any advice.
Old October 16th, 2001, 07:05 AM   #2
got to the nearest international airport, and you will be able to find a plug converter to do the job you want. My XL1 is an Australian Pal version and I am using it in Japan with a similar adapter
Adrian Douglas is offline   Reply
