Windows Premiere Pro CS4 Importer Beta at DVinfo.net
CineForm Software Showcase
Old March 11th, 2009, 10:28 PM   #1
CTO, CineForm Inc.
For those who can't wait any longer:
http://miscdata.com/cineform/CFHD_CS4_importer.zip
It is the vanilla importer with no installer.
It contains:
CFHDDecoder.dll
CFHD_AVI_Importer.prm
The DLL must be installed in you execution path, if you don't know which directories are in this path, use c:\windows\system32. DO REMEMBER where you put it as it will need to be deleted before installing any official CS4 supporting installers, just in case. You have been warned.
The PRM file goes in
C:\Program Files\Adobe\Common\Plug-ins\CS4\MediaCore
or
C:\Program Files (x86)\Adobe\Common\Plug-ins\CS4\MediaCore
Remove any our *CFHD*.prm file you might find.
Then start up PPro CS4.
This importer supports all the 32-bit float formats and a few other deep pixel formats, so it is a lot better than using the VfW codec many are currently using.
Old March 12th, 2009, 06:58 AM   #2
Great news! Do you have any time frame on when the final will be released?
Brant Gajda is offline   Reply With Quote
Old March 12th, 2009, 07:43 AM   #3
Thanks. Sorry to ask such a stupid question but where do we stand with after effects? Obviously this is intended for Premiere but I'd love to get a few of these clips into AE also.
Is that already supported? I wouldn't think so but thought I'd ask.
Thanks again.
Marty Hudzik is offline   Reply With Quote
Old March 12th, 2009, 08:48 AM   #4
needs to go in the c:\Windows\SysWOW64
It contains:
CFHDDecoder.dll
or
Doesn't the dll need to go in the c:\Windows\SysWOW64 if you're using XP 64bit? Only way it'd work for us. Plus, obviously there are no presets...
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply With Quote
Old March 12th, 2009, 09:05 AM   #5
CTO, CineForm Inc.
Stephen,
Cool, SysWOW64, use that. I didn't need to I my XP64, as system32 was in my path.
Presets have nothing to do with importers, that is for playback modules which is a while off.
Old March 12th, 2009, 09:06 AM   #6
CTO, CineForm Inc.
When people test it, we will know when it might be ready for release.
Old March 12th, 2009, 09:08 AM   #7
CTO, CineForm Inc.
Thanks again.
After Effects and Encore use the same component from the MediaCore path, so it should work fine. We have done zero testing in AE, so please give that a go.
Old March 12th, 2009, 09:38 AM   #8
the importer seems to work fine for me, as now i can play the timeline fine without any stuttering in premiere cs4 with my 5d mkII files, i take it this importer when working in the background is totally transparent, since now i just drop my .avi files directly into premiere and onto the timeline
Gary Greenwald is offline   Reply With Quote
Old March 12th, 2009, 10:44 AM   #9
CTO, CineForm Inc.
Yes, the importer operation is basically invisible when it is working correctly. It will be significantly faster than using the VfW codec, as Premiere's draft and automatic playback modes ask for half resolution decodes, giving you smoother playback.
Old March 12th, 2009, 04:45 PM   #10
Hello David
Could you please tell me what’s the different between a full Prospect HD as I have now on my CS3 installation and this ” importer” installation. I’m a Swedish guy so stand by me in this it’s to hard to grasp this.
Mikael
Mikael Bergstrom is offline   Reply With Quote
Old March 12th, 2009, 04:51 PM   #11
CTO, CineForm Inc.
Importer = open CineForm files
Prospect HD = Real-ime pipeline, effects, transition, HDSDI capture and playback.
The importer is all we add to NEO to make it Premeire compatible, Prospect is all the extra stuff.
Old March 12th, 2009, 05:19 PM   #12
That's great news! Do we have to desinstall Neo Scene before installing manually the files you mention in your post?
Guillaume
Guillaume Roques is offline   Reply With Quote
Old March 12th, 2009, 05:34 PM   #13
CTO, CineForm Inc.
Guillaume, Do nothing more than the instructions provided.
Old March 12th, 2009, 05:46 PM   #14
Thanks David, so if I capture through Prospect HD in Premiere CS3 3.2 and open up these files in Premiere CS 4 it will work, right?
Will it have Decklink support on the playout now, the HDMI or SDI out of those cards, I've been waiting long time now for this?
PS Just love to buy your CS4 4K Prospect HD now:-)
Best Regards
Mikael
Sweden
Old March 12th, 2009, 05:51 PM   #15
For us Vista 64 users,should the file go in:
C:\Program Files (x86)\Adobe\Adobe Premiere Pro CS4\Plug-ins\Common
Cause there is no path that you specified.
