New releases for Mac and PC are out. - Page 2 at DVinfo.net
CineForm Software Showcase
Old October 16th, 2010, 04:20 PM   #16
No probs... I will open a ticket, thanks David.
Rich Perry is offline   Reply With Quote
Old October 16th, 2010, 07:36 PM   #17
Can somebody explain what the proxies option is for?
Laurence Kingston is offline   Reply With Quote
Old October 16th, 2010, 08:21 PM   #18
CTO, CineForm Inc.
Proxies are particularly useful for 3D, as stereo 4K is a bit of a burden for many systems. Also 2K RAW on some systems is compute intensive enough. If someone were to generate DNxHD or ProRES proxies, they losses all the benefits FirstLight and no-longer have color/3D metadata travel from the edit in finishing. CineForm proxies are like no other in that perform all the color/3D active metadata corrections identically to their parent/master files, and changes that are applied on proxies automatically apply to the master files. In Avid MC5 and FCP 7, these tools really prefer 1080 sources, if you shoot >2K+ you can be in trouble, so proxies help there also. In most cases proxy files are not needed, as CineForm masters edit smoothly, but there are many extreme projects which CineForm is used more commonly (e.g. we've done a lot of IMax files) and these are the project where these files are most welcome.
Old October 16th, 2010, 08:36 PM   #19
Do you have to do anything special to use the proxies aside from checking the box? Is there a discussion some place of this I can look at?
Old October 16th, 2010, 09:12 PM   #20
CTO, CineForm Inc.
It has been briefly mentioned a few times in the last few beta releases, but nothing else written up yet. There will be a techblog.cineform.com article soon.
Other then checking proxy, and typically fast scale with a smaller target size, your sources must be your CineForm master files.
Old October 17th, 2010, 02:58 AM   #21
Looks like same old problem keep on coming back.
I did convert some older 5D2 files 30fps to CF AVI. Audio did not sync any more.
System is Vista 64 and Vegas Pro 10.
Hannu Korpinen is offline   Reply With Quote
Old October 17th, 2010, 10:49 AM   #22
CTO, CineForm Inc.
Easy to diagnose, are the clips flagged as 30.0 or 29.97fps? Do they play out of sync in mediaplayer, or is simple more samples in the audio than video? From the screen shot not much can be learned, other than look like the audio playing about 18% slower than the video, which is not an known bug (.1% is more typical for 29.97 vs 30 issues.) Please fill a trouble ticket with support.
Old October 17th, 2010, 12:46 PM   #23
At least Vegas Pro is showing original 30fps and CF avi 29.97fps.
But ok I can use original files instead CF. VP 10 will be now faster previewing original mov files. Propably CF files will be later as fast or faster playing with Vegas 10.
Old October 17th, 2010, 01:20 PM   #24
CTO, CineForm Inc.
We convert to 29.97 as a default, as 30.0 is not commonly used. If you want 30.0 there is a option to turn that off, will written here somewhere on the forum or support can tell you.
Old October 17th, 2010, 11:16 PM   #25
first light v5 beta mac:
Looks are working now, nice.
tools not working. - cannot get histo/rgb.. etc any of those to appear.
Justin Lovell
cinematographer//8mm.16mm>HD.transfers . www.framediscreet.com
Justin Lovell is offline   Reply With Quote
Old October 18th, 2010, 08:16 PM   #26
I should add my voice to Rich and Roger's chorus - I'm having a similar issue.
I upgraded to Neo 4K 5.20 and in Premiere CS5 the playback would hang after a second or two. I uninstalled 5.20 and then reinstalled 5.13 - it now works fine.
I don't have any Matrox hardware installed, but I did just install a Blackmagic Intensity Shuttle. I don't think I tried 5.20 prior to installing the Shuttle, so I can't vouch for the effect of the Shuttle.
- Rick
Rick Thornquist is offline   Reply With Quote
Old October 18th, 2010, 08:23 PM   #27
CTO, CineForm Inc.
As the isn't being commonly reported, please file a trouble ticket.
Old October 19th, 2010, 02:26 AM   #28
I'm having similar problems.
CS5.0.2, Win7 64.
Mid project with N4K 5.10 b 268, no problems, smooth as glass.
Installed N4K 5.2- same project has playback hangs, image in program monitor stays the same when moving CTI, or changing sequences until playback actually starts, then image refreshes.
Also noticing very marked interlace artifacting with playback- never a problem before.
Sometimes refuses to open or close sequences.
On changing playback rez in program monitor I got the BSOD.
No Matrox, Blackmagic, etc., just straight CS5.
BTW, all the CFHD is on RAID 0- no bottleneck issues.
I do have Open GL turned on- seems like the only way I can get my HDTV monitor to get full screen overlay with Quadro fx 3800 (using N4K 5.1xxx, or 5.2).
Anyway, I rolled back to 5.10 and all seems to be well for the moment.
I've never had any problems at all with any of the prior v 5xx updates.
Seems like something is afoot with v 5.2 :(
Bob
Old October 21st, 2010, 08:11 AM   #29
I'm in the middle of a project on Premiere Pro and, with 4 tracks of videos/stills, my computer is grinding to a halt. I converted my Cineform master files to proxy. Do I now need to reimport them into PP? I want to save existing edits, but move over to the proxy files.
Thanks.
Patricia Lamm is offline   Reply With Quote
Old October 21st, 2010, 10:12 AM   #30
CTO, CineForm Inc.
To use proxies, with premiere closed, swap out the prioxy files for the masters, i.e. most the masters somewhere else (a sub folder, so the move is instant) and when Premiere "says where are my files?", point it to the proxies.
