Adobe CS3/CS4 + MainConcept = Great News - Page 5 at DVinfo.net
Convergent Design Odyssey
Old November 20th, 2009, 02:03 PM   #61
Hi Paul. I am guessing you are doing something wrong. The prores files I exported are not distinguishable from the source file.
Aaron Newsome is offline   Reply With Quote
Old November 20th, 2009, 02:10 PM   #62
Interesting Aaron I have tried a few other shoots I did with the Nano and with out the Nano and the clips in Prores HQ are very noisy.
Paul Cronin
www.paulcroninstudios.com
Old November 20th, 2009, 02:33 PM   #63
Are you exporting the raw clips directly with Compressor or from the timeline in FCP. Also, I solved the FCP XML to Premiere issue too. Premiere is expecting an older XML format so it will choke on new XML format. I have a fix for this.
Old November 20th, 2009, 02:43 PM   #64
I imported the clips to FC then put them on a Prores HQ timeline with no render needed. Then I export them out from the FC timeline.
But now I am sending the client MXF from the raw clips and I will buy them the plug in since it has to go Priority in 10 min. But figuring this out so next time I can use XML or other options works for me.
Paul Cronin
Old November 20th, 2009, 07:53 PM   #65
I tried this again right now. I can't see the difference between the original clip and the prores. Can you shoot a short clip and post both versions. I can post my clips you if like.
Old November 21st, 2009, 03:36 PM   #66
Aaron,
I was on a shoot all day and again tomorrow. Monday I should be able to post the same clip from both but they will be downgraded for the web. If it still shows well it will at least make my point at what I am seeing.
Thanks for the help.
Paul Cronin
Old November 21st, 2009, 03:43 PM   #67
Paul, you can upload the clips directly to my server. There's terrabytes of storage there. You may want to shoot a short clip, maybe 10 seconds or so. Then the files size of the original and the ProRes will be pretty small.
Compressing them for the web really won't help me understand what's going wrong.
Old November 21st, 2009, 03:50 PM   #68
Excellent I have a short clip and maybe tomorrow I will have a chance if not Monday will work. Out the door now.
Did you send my your FTP once before? I will see if I still have it or deleted it.
Thanks Aaron.
Paul Cronin
Old November 23rd, 2009, 08:48 AM   #69
Careful in purchasing the plug-in from Main Concept.
You have to make sure they send you the correct link or you will end up paying full price.
Paul Cronin
Last edited by Paul Cronin; November 23rd, 2009 at 08:53 AM. Reason: update after problem solved
Old November 23rd, 2009, 12:56 PM   #70
Dear Friends,
I will attempt to assist anyone that has a problem with the reduced price offer for the MainConcept Plug-In for Adobe CS3/CS4.
Our contact with MainConcept is very responsive.
Please let me know if I can assist.
Dan Keaton
Augusta Georgia
Old November 23rd, 2009, 03:06 PM   #71
Dan,
Astrid helped me out. The problem is they do not have a options for buying with the discount. So they are in the process of adding that options. The store is run by a different company.
Astrid did a great job helping me.
And I have not heard from the client so no news is good news when it comes to how the plug-in works.
Paul Cronin
Old November 25th, 2009, 06:07 AM   #72
Aaron I put two clips in your folder. Thanks for checking them out.
Paul Cronin
Old November 25th, 2009, 11:49 AM   #73
Looking at them right now Paul.
Stay tuned.
Old November 25th, 2009, 11:54 AM   #74
Great just getting ready to send the hard drive out today.
Paul Cronin
Old November 25th, 2009, 12:51 PM   #75
Paul. I see what you mean. That ProRes422 file is unacceptable. I'm not sure what noise you're talking about but the jaggies on the building edges are enough for me to reject them.
I'm looking into what might be causing this now.
