Recording to NF without tape at DVinfo.net
Convergent Design Odyssey
Old March 20th, 2010, 08:04 PM   #1
If I set the seed function for TC to be generated in the nanoflash.. it will run TC when I press the record button on the nano.. but will audio come from the HD SDI out of the camera in this mode,as well as picture..
Robin Probyn is offline   Reply With Quote
Old March 20th, 2010, 10:50 PM   #2
Dear Robin,
If audio is embedded in the HD-SDI stream, and you have audio set to Embdded, the nanoFlash will record audio regardless of whether you trigger via incrementing timecode, or any other method such as the record button or remote control switch.
The same applies if you are using the external analog audio inputs.
Dan Keaton
Augusta Georgia
Old March 21st, 2010, 12:54 AM   #3
Hi Dan
Ok thanks for the prompt response as ever !!
