nanoFlash Settings For Sony EX3
Having today acquired my newish EX3 I wonder what the settings should be with my nanoFlash, up until now used with a Canon XLH1.
I would trigger the nano from a remote cable, timecode internal, i.e. not from the EX3 and audio embedded in the HD-SDI signal from the camera. Maybe no difference to what I'm doing with the XLH1 except that there audio is taken from the audio out sockets on the cam, as it is not embedded within the HD-SDI signal, at least not on my original version of the XLH1. I would not expect to be recording to the EX3 simultaneously with recording to the nanoFlash. Ron |
Re: nanoFlash Settings For Sony EX3
If you are not using a record trigger from the EX3, your current settings look good.
If you are using a timecode record trigger from the EX3, Choose "Last TC > TC" as the record trigger, as that will prevent bad recordings when your camera goes into Rec Review. |
Thanks Jack. I connected the nanoFlash as per my current "XLH1" settings except embedded audio and off she went.
Ron |
