mxf to mpeg hd bitrate at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old July 7th, 2011, 06:22 PM   #1
i have some footage from a sony ex3. mxf files that i need to convert to mpeg2. what bitrate should i use to get the best picture. I am using adobe media encoder. I used mpeg 2 1080p at 23.976 with a bitrate of 60mbps is that high enough?
also what would be a better format to convert to if i don't use mpeg2 ?
Dave Morgan is offline   Reply With Quote
Old July 11th, 2011, 12:36 PM   #2
Re: mxf to mpeg hd bitrate
Sounds like you don't NEED mpeg2. That's the native format for DVD's, and is going to degrade your image.
So the question is, "What are you doing next with that footage?"
Andrew J Morin is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
