Glidetrack Shooter .5 meters or 1 meter? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old February 3rd, 2010, 03:01 PM   #1
I would like some feedback on Glidetrack (regular model or Shooter model) users on which length you are using. I'm leaning towards the .5 meter length since I'll most likely use it during my day hikes so portability would be an issue there. However, I have some doubts whether .5 meters is actually long enough? There are several hikes that I want to do that are only 1-2 miles long with beautiful views so I'm thinking that that 1 meter length wouldn't be too much of a burden to carry around strapped to by backpack.
I know there are tricks to using it like using a longer focal length to give it the illusion that the actual slide looks longer. I also have some projects in mind to use it around town. If you had a choice, which length would you choose?
Thanks in advance!
P.S. - I will be using a Nikon D90 and a Canon HF11 on it if it matters.
Ray Pempengco is offline   Reply With Quote
Old February 3rd, 2010, 03:43 PM   #2
Sponsor: Westside AV
Ray,
As you may know I make a Igus track system slider as well.
The most popular size is 3'. I make any custom size you need.
It is small enough to carry anywhere and gives you a long enough slide for a 10-15 second slow slide.
I have a few tips and some sample videos on my site:Reasonable Priced Sliders ? Westside A V Studios
You can also call me and I will give you some tips over the phone:
olof@westsideav.com
603.383.9283
Old February 3rd, 2010, 06:48 PM   #3
The 39" isn't as portable, but is nice because you can use it as a jib/crane.
Old June 17th, 2010, 07:46 AM   #4
Ive only used the 1m, and I am in the process of purchasing one! There are a lot of benefits of having the 0.5m, but due to its size you are very limited, and taking into account you will need an inch or 2 either side to get the tracking shot smooth you may struggle with the 0.5m. The 1m is still very light and portable, therefore you could still take it on your hikes.
I would recommend the 1m, this was what I ended up deciding on.
Lloyd Morgan Productions
Video Production UK
Lloyd Morgan is offline   Reply With Quote
Old June 17th, 2010, 12:30 PM   #5
I agree - the one metre length is very portable and gives a good impression of movement. I use it on nature walks.
The slider is also very useful not just for movement , but to get the lens outside the centre of the tripod's triangle... You can really hang it in places where you normally couldn't get the lens.
Old February 20th, 2011, 11:37 AM   #6
Sorry, I misposted to wrong thread.
Jim Snow is offline   Reply With Quote
Old February 20th, 2011, 11:58 AM   #7
Ray,
Why don't you ask Alastair at Glidetrack to make you a 75 cm version of the slider? When I bought mine that's what I got. Going to East-Africa to do a documentary I had to transport the Glidetrack in my suitcase.
The one meter version was just too long for that.
Best,
-terje
Terje Rian, Creative Director
www.notene.no
Terje Rian is offline   Reply With Quote
Old February 21st, 2011, 10:29 AM   #8
Re: Glidetrack Shooter .5 meters or 1 meter?
Hi Ray,
You will be pleased to learn that 0.75m is a stock item at Glidetrack.
Best Regards
Alastair
Alastair Brown is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
