Salt Flats running vid. - Page 2 at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon EOS Full Frame for HD > EOS Full Frame Sample Clips Gallery
Post your 1D / 5D / 6D clips here... Vimeo links will automatically embed a player right in the post.
Old May 19th, 2009, 10:24 AM
Derek Weiss Derek Weiss is offline May 19th, 2009, 10:24 AM
5DMII, Steadicam, a short bit of helicam.
Salt Flats on Vimeo
Derek Weiss
Old May 20th, 2009, 06:30 AM   #16
Chad,
The heli is a small electric with 600mm blades (Trex) with a custom front mount. It weighs about 13lbs in flight.
Derek Weiss is offline   Reply With Quote
Old May 20th, 2009, 11:52 AM   #17
Very interesting how you kept your lady's colours of skin, hair & gear accurate, while the desert was blown out but the background hills and sky stayed in reasonable colour. The 5D2 manual might tell me how you did it but have you time to tell me the technique?
Brendan Marnell is offline   Reply With Quote
Old May 20th, 2009, 12:09 PM   #18
Brendan,
We were shooting from Noon to 4pm with the sun very high in the sky. The salt flats are very much pure white, obviously because it is all salt. So meter for the skin tones or just slightly above and the rest gets clipped. The hills in the background are very dark brown to nearly black which again helps with an almost bichromatic landscape.
Old May 20th, 2009, 01:45 PM   #19
That is helpful Derek, thanks.
Now I'm getting serious about investing in 5D2, especially after seeing how you retained image quality (after Vimeo) with your Triathletes. At a range of distances it was possible to see muscles moving even in sepia ... could help me get and hold sharp focus of big birdflight. I must read up about follow focus/peaking/zebra lines or whatever else might help ... your suggestions could be precious to me and others?
Old May 20th, 2009, 03:11 PM   #20
Originally Posted by Brendan Marnell View Post
...I must read up about follow focus/peaking/zebra lines...
Once you start shooting, the support is weak - No HD output for monitoring critical focus, no zebras, just an SD output on the LCD screen. It's best to use a HoodLoupe or external SD 4x3 monitor (if you can find one with a true 480 lines.)
The camera does well before you record though. It has 5x and 10x magnification, which helps you mark your focus points. You can take a photo and check the histogram to check levels and confirm that the color balance isn't ridiculous.
One of the strongest features - if you are brave enough and have enough time to use it - is the custom picture profiles. You can take a RAW photo, tweak it with the profile editor and save it in the camera. That processing then occurs in the 14-bit domain, before the h.264 encoding. You can tweak sharpness, contrast, tone and saturation, mess with the luma curve, and select certain color regions to modify. It's challenging though. You might approach the luma curve or color corrector with a certain vision, but the software often doesn't let you get there from here.
That said, if you can master the custom profiles, you can potentially get very close to your desired look. You can then make fine adjustments in the 8-bit domain, rather than trying to push too few bits too far.
Jon Fairhurst
Old May 20th, 2009, 04:59 PM   #21
"The Hoodloupe looks good to me."
"How does auto-focus behave in Live View? Is there even an X in centre screen?"
"Checking with histogram is a good suggestion."
"Are those features for stills only or can they be applied to video? I like h.264 but I never use RAW and it's my ignorance of luma that deters me from the curves."
"Custom settings may take me a while to decide. But 8-bit and 14-bit domains are foreign to me at this stage."
Thank you for all the insights. Looks like I'll be nagging you as long as I get away with it ...
Old May 20th, 2009, 07:49 PM   #22
Derek,
What's the longest lens/focal you use on the Helicam/MKII?
Or do you just keep it all super wide?
Cheers,
Jeff
Jeff Scholl is offline   Reply With Quote
Old May 20th, 2009, 08:49 PM   #23
I've got to admit it. I'm obsessed with the 5D Mark II. There's no limit...
Speaking of which, here's the latest on the 5D MkII shutter: http://www.dvinfo.net/conf/canon-eos...part-ii-6.html
And you can see my first exploration into shutter speeds here : Canon 5D Mark II Shutter Exposed on Vimeo
I've done more tests, and plan another video, in time....
Jon Fairhurst
Old May 20th, 2009, 09:51 PM   #24
Originally Posted by Jeff Scholl View Post
Derek,
Cheers,
Jeff
I primarily use the 24mm and 35mm prime. If the winds are light, rarely a 50mm.
Old May 23rd, 2009, 04:19 PM   #25
Salt Flats on Vimeo
Well done. Great steadycam work! Very balanced. It is a difficult task to do a decent follow focus on a steadycam. I love your clean picture and lots of white spaces used. Very impressive!
Borden Li is offline   Reply With Quote
Old May 24th, 2009, 02:14 PM   #26
Derek, very nice indeed -- I even like the editing. Do you happen to have a snapshot of the helicam rig?
-- peer
www.NoPEER.com
Old May 24th, 2009, 02:19 PM   #27
Once you start shooting, the support is weak - No HD output for monitoring critical focus, no zebras, just an SD output on the LCD screen. [etc.]
Jon, it's comprehensive info like this that makes you my hero. Thank you so much for yet another thorough write-up.
-- peer
www.NoPEER.com
Old May 24th, 2009, 07:59 PM   #28
I'm glad to contribute!
Jon Fairhurst
Jon Fairhurst is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon EOS Full Frame for HD > EOS Full Frame Sample Clips Gallery
