Final Cut Pro audio question: reverb at DVinfo.net
Final Cut Suite
Old February 17th, 2008, 01:13 PM   #1
MPS Digital Studios
I need to make a voice over sound like it's in an echo-ish hallway (outside), but I'm trying to find a good audio filter in Final Cut Pro 6. Any thoughts?
heath
My Final Cut Pro X blog
Old February 17th, 2008, 02:21 PM   #2
Soundtrack pro should have what you need. I beleive its called Space Designer in the reverb section of the FX.
Matt Stahley is offline   Reply With Quote
Old February 17th, 2008, 02:25 PM   #3
MPS Digital Studios
thanks! I'll give it a shot.
heath
Old February 17th, 2008, 02:57 PM   #4
Yes, SpaceDesigner should give you great results. Check out the many presets for different types of rooms that it has.
As far as I know, there's nothing built right into Final Cut Pro that can do anything similar. So definitely export your audio to Soundtrack Pro and add the reverb/echo there.
- Martin
Martin Pauly
Martin Pauly is offline   Reply With Quote
Old February 19th, 2008, 04:14 PM   #5
There are many adjustable Reverb filters built right into FCP to give you just what you need.
http://desertdudefilms.com/
Pasquale Benedetto is offline   Reply With Quote
Old February 24th, 2008, 02:23 PM   #6
MPS Digital Studios
I used FCP, tweaked it and it worked fine, thanks! I don't use Soundtrack Pro, believe it or not. Mostly because I have friends that do the audio editing for me, separately. I trust the audio experts!
heath
Old February 24th, 2008, 02:38 PM   #7
Images: 1
heath
Space Desinger is a superb convolution type reverb plug-in. If you just learn to use one plug-in in STP, that would be one I'd suggest. Those settings are 'sampled' spaces using a process called IR (impulse response), typically created by recording a starter pistol or better yet, a sine wave sweep. The de-convolution process then removes the original impulse, leaving only the response characteristics. This leaves a very realistic sounding reverb when applied to your own audio source.
-gb-
Old February 24th, 2008, 02:40 PM   #8
MPS Digital Studios
Thanks for the info, Greg. I got lucky with my film: Douglas Spotted Eagle helped me with some audio clean up. Spot's truly an audio expert!
heath
