FCP 6 Dissolve problem at DVinfo.net
Final Cut Suite
Old March 27th, 2008, 03:01 PM   #1
I am trying to add dissolves and something has changed because I have a new problem.
I can click the cut and type command T and the dissolve appears but only starts on the cut and goes for 1 frame. My dissolve is set for 1 sec 15 frames. Now some of the cuts it works fine and some it does not.
I have checked that the video either side of the cut has enough room so that is not the problem.
What am I missing?
Paul Cronin
www.paulcroninstudios.com
Old March 27th, 2008, 03:03 PM   #2
Never mind a reboot solved the problem.
Paul Cronin
Old March 27th, 2008, 09:01 PM   #3
zoom in. you probably have a 1 frame gap between the clips... or you really don't have the media, or... trash FCP prefs
Steve Oakley is offline   Reply With Quote
Old March 28th, 2008, 07:34 AM   #4
Thanks Steve but no blank frames. Weird a reboot has solved it.
Paul Cronin
Paul Cronin is offline   Reply
