Sound Sync not Exporting at DVinfo.net
Final Cut Suite
Old May 4th, 2008, 02:48 PM   #1
I have a Quicktime concert file that is out of sync.
I have brought it back into Final Cut and re synced it (at many different points)
It plays great in Final cut,
but goes out of sync again when I out put it.
I have tried DV NTSC & PAL to no avail,
Any Ideas ?
J
John Benton is offline   Reply With Quote
Old May 4th, 2008, 10:32 PM   #2
Figured it out:
Tape was originally PAL
you need to set FCP to be PAL
then import, re sync export...
I also added Slugs in between the clips - I believe this helps keeping Sound set in the timeline
J
