Loss of footage quality using motion in FCS Pro at DVinfo.net
Final Cut Suite
Old September 9th, 2008, 11:57 AM   #1
I am working with 720p 30Hd footage in FCS Pro. I repositioned some footage creating a canted angle using motion and slightly enlarged the footage to hide the corners from the adjustment. Now the footage quality is practically useless. Have I done something wrong or is this normal. I am relatively new to final cut so i apologize if there is a simple solution.
David Allen Smith is offline   Reply With Quote
Old September 9th, 2008, 12:25 PM   #2
You could just be looking at the footage in draft mode. Also, check your Sequence/Settings/Video Processing make sure to render in high precision YUV and Best quality motion.
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/
Rick L. Allen is offline   Reply With Quote
Old September 9th, 2008, 12:32 PM   #3
So once I render out of FCP this issue should be resolved?
