Strange Capture Problem!! - Page 2 at DVinfo.net
Final Cut Suite
Old December 8th, 2003, 07:11 AM   #16
Warden
Try capturing to an external drive. Also try capturing with a non Canon brand camera.
Jeff Donald
Carpe Diem
Old December 8th, 2003, 11:18 AM   #17
Eugene,
How are you trying to capture? Log and Capture? I have had timecode issues with FCP saying it cannont read the timecode. So, now, most of the time I just start the tape and hit "Now" in the capture box. That works for me, that way, FCP doesn't even worry about reading timecode (I think). Try this....hope you find a solution...please let us know what you end up figuring out....
Clay
I understand everything about nothing.
J. Clayton Stansberry is offline   Reply With Quote
Old December 8th, 2003, 11:27 AM   #18
Contributor
It might just be a transport control problem. Try setting firewire transport control to 'basic' instead of 'apple'. Worked for me. I had a similar problem using FCP and a PDX10.
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands.
Ignacio Rodriguez is offline   Reply With Quote
Old February 3rd, 2004, 03:59 PM   #19
hi Eugene,
thanks for your post in my thread! No, you are not alone. I seem to have a similar setup with exactly the same problem: XL1-s, Powerbook G4, never had any problems in FCP3, continous timecode, capturing to internal 80GB or external 250GB -> same problem.
It is soooooo annoying having to capture a tape in 8 times or so, especially syncing it all up again afterwards.
My wild guess is it has to do with the XL-1 specifically or Canon cameras in general. I heard Canon's implementation of Firewire has got some problems built in. Have you tried the FireWire Basic protocol? Did you get any further? Got any hints or tricks?
Greetings! Hope you get ahead anyway. (I myself am stuck on a Brazilian documentary...)
Oliver.
Oliver Pollak is offline   Reply With Quote
Old February 9th, 2004, 02:01 AM   #20
hi Oliver!
Nowadays I set capture settings on 'non-controllable device' instead of the firewire Pal- setting.
You have to press play on your XL1s, en then press the capture button : capturing will start, en recently I managed to capture 4 tapes without any problems.
'Non-controllable device' is the solution. Try it!
Eugene Presley is offline   Reply
