#1381 |
Hi Tim,
Check out this link. http://www.kenstone.net/fcp_homepage/qt_movies_from_fcp.html Jerome |
#1382 |
yea i figured out print to video which gives me the tone and color bars I needed as well. But I couldnt get it to record on the camera. Eventually I learned that not only do you have to push the vcr rec button on the camera but the saftey button next to it, this way you never accidently tape over stuff in VCR mode....well it almost cost me my entry...but it should already be there now. Thanks for your help.
#1383 |
trashed preferences.....where is everything?
Long story longer.
(g-4 dual 1.25, aaja kona sd card 2 medea raid drives, beta 1800 and a dsr-45 running thru AJA card and monitor, piggybacked) I had to trash preferences. mac stopped seeing the medeas' on start up. trashed 'em and it now it sees them. dont know how that worked but im not questioning it. however, 'Effects handling' now says FCP with the option of none, where they all said Blackmagic before. also, the beta and dsr routed monitor see video during capture and clip playback but not in the timeline and will not record video using crash record or print to tape. audio is there. i reinstalled Kona to no avail. im in a pickle. any thoughts? |
#1384 |
Warden
When you reinstalled Kona was FCP open? Make sure the application is closed before installing options or plugins. When you trash preferences you're setting all your custom settings and options back to Apple defaults. You need to set your settings and preferences back to the way you had them before.
Jeff Donald Carpe Diem Search DVinfo.net for quick answers | Where to Buy? From the best in the business: DVinfo.net sponsors |
#1385 |
yes, i beleive it was.
should i close and reinstall? |
#1386 |
I think there is a button in the print to video window to automatically start recording. It looks like I am too late, I hope you figured it out.
#1387 |
To countinue my thread of panic.
have discovered that the clips in the broswer while played in the viewer will export and crash capture. i still cannot export the timeline. where to look next? |
#1388 |
Warden
Try deleting Kona again, and reinstalling it, but with FCP closed. You can't have a program open and update it, at the same time. Your FCP preferences may need to be trashed again as well. I would trash preferences in FCP. Startup FCP, then close it. Install Kona software. Repair permissions to System drive using Disk Utility, Start FCP and set preferences (personal settings) back to the way you want them.
#1389 |
Converting 4:3 to widescreen?
Hi all
I've filmed some stuff in 4:3 mode on my XLs1 and I want to show it as widescreen. Can I just mask it so that it plays OK on a 4:3 tv and can be displayed OK on a widescreen tv??? Is there a nice way to do this in FCP4.5??? I've used the filters but they all require rendering which is a pain. Can't I just stick a photoshop file on top of the footage to get this effect without rendering??? I've tried a few things but I'm unsure of the best way to go about it. Searching the web is not getting me further either. I'd appreciate if soembody could explain the correct way to achieve this... A photoshop mask file would be appreciated as well if that's the way to go... Many thanks Donie
Macbook Pro 2.0Ghz and Canon XL2 |
#1390 |
I don't think there's any way to do this without rendering unfortunately. Do you just want to letterbox? That would be the only way for it to look right on a 4:3 TV. On a widescreen TV it will still be letterboxed, but most of them have a "zoom" mode which will cause it to fill the screen.
Another approach might be to turn it into anamorphic 16:9 by cropping and stretching, then burn to DVD. The DVD player will automatically provide a letterbox for 4:3 sets. Of course this will also require rendering. Here are a few related threads which might be of interest... http://www.dvinfo.net/conf/showthrea...threadid=31987 http://www.dvinfo.net/conf/showthrea...threadid=27748 http://www.dvinfo.net/conf/showthrea...threadid=30068 http://www.dvinfo.net/conf/showthrea...threadid=25441 http://www.dvinfo.net/conf/showthrea...threadid=24850 http://www.dvinfo.net/conf/showthrea...threadid=16465 |
#1391 |
<<<-- Originally posted by Boyd Ostroff : I don't think there's any way to do this without rendering unfortunately. Do you just want to letterbox? That would be the only way for it to look right on a 4:3 TV. On a widescreen TV it will still be letterboxed, but most of them have a "zoom" mode which will cause it to fill the screen. -->>>
Thanks Boyd, I'm begining to understand... Do you know the values which are normally entered into the crop for the letterbox shape to be acceptable? I guess it's about 10% or more at top and bottom, but how many lines exactly shoudl I use to be 100% correct? Many thanks Donie
#1392 |
<<<-- Originally posted by Donie Kelly : how many lines exactly shoudl I use to be 100% correct? -->>>
You should crop 60 lines from the top and 60 from the bottom such that the active image area is 720x360. |
#1393 |
Hey Jeff,
Thanks for your suggestions. I talked with the Kona support and they just had me update my drivers. worked out all the bugs. duh |
#1394 |
Cool, thanks Boyd, many thanks...
#1395 |
Uninstall FCP4 and Trashing preferences
ok, so i searched a little trying to find out exactly how to completely uninstall fcp4 as well as how to trash preferences.
I couldnt get any help, so im making a thread thats clearly about this alone. I tried just deleting the fcp program in the app folder, but when reinstalling, it refered to the install as an upgrade... then when i opened fcp it was as if id not done anything new. i was never asked for my licence code. How do i completey remove all traces of fcp4 so as to do a clean install? on a similar note, how do i just trash the preferences so that im starting from default again on everything without a reinstall? i wish i were smarter, but resourceful's gonna have to be enough. heath
Heath Hays MGD Productions |
| Thread Tools | Search this Thread |
