Worth upgrading to Snow Leopard for FC? - Page 3 at DVinfo.net
Final Cut Suite
Old August 31st, 2009, 07:23 PM   #31
Go Go Godzilla
Images: 15
Absolutely Not
It would seem that Apple has instead released a "white elephant" rather than a Snow Leopard.
With all the research in white-papers and ADC docs there didn't seem to be anything to indicate any serious compatibility issues however, real-world testing has shown that once again Apple has delivered a wonderful glossy ad campaign only to disappoint on the delivery.
We've uncovered and run into literally dozens of bugs and mission-critical failures caused by the SL kernel and core communication changes. Everything from FCP6 to FW has been affected adversely and the net is flooded with complaints - including a few DVinfo users - on failures from connecting previously running external devices to apps that crash the entire system.
And then there's this bit of not-so-obvious news on the 64-bit environment which I did not see covered in any white-papers:
64-bit Snow Leopard defaults to 32-bit kernel | Apple - CNET News
The bottom-line for pro-app users: Don't upgrade to SL. If you did hopefully you saved your previous OS image (see the sticky I posted about saving your system) and can restore your previously good-running system.
It may well be into next year before Apple has time and resources to address all the problems just now surfacing.
P2, SxS and ExpressCard users especially beware: DO NOT attempt to use your external devices or connect media with money-making clips to a SL system.
Old August 31st, 2009, 07:33 PM   #32
As much as I work with P2, I'm holding off until they address this driver issue. If I never plug in a Panasonic camera with firewire/usb that'd be fine with me. My love for duel adapter and MBP is too important. Also, can anyone confirm MXO 1 & 2 support in SL?
-C
Old August 31st, 2009, 08:57 PM   #33
I really don't hope it takes that long for them to fix the Express Card problem.
Chris Leffler is offline   Reply With Quote
Old August 31st, 2009, 09:11 PM   #34
Go Go Godzilla
Images: 15
Don't wait for them to play catch-up; get back on 10.5.8 and get back to work. Until all the major pro apps actually become 64-bit native there's really no need for SL. Only Apple consumer apps (and a limited few) will actually benefit, nothing else.
Old September 1st, 2009, 08:26 AM   #35
I don't think Snow Leopard is a 'white elephant' at all. It's a major change in the operating system and some things won't work for a while... just like switching from OS9 or switching from Win2k to XP to Vista to 7.... no one in their right mind would switch a production machine over to a new OS until the workflow got straightened out.
But, if speed is important to you, Snow Leopard's new Qucktime engine is worth the hassle. So far, it looks like it will cut 20 minutes off my overall output times for 2 minute news pieces.
Chuck Fadely is offline   Reply With Quote
Old September 1st, 2009, 09:01 AM   #36
Images: 32
Chuck, after all your experimentation, what's your current workflow in Snow Leopard? Where have you seen the most significant speed improvements when encoding video?
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old September 1st, 2009, 10:19 AM   #37
Michael, I installed Snow Leopard and FCS3 on a MacBook Pro on Friday. A weekend isn't enough time to figure out all the workflow issues.
But if you output from FCP at 'current settings' it is really fast. A two-minute HDV timeline makes a self-contained .mov in less than two minutes.
If you then pull that self-contained .mov into Quicktime Player X, and do a 'save as' at HD 480 P movie setting, you get a 640x360 h.264 file with 44khz audio in less than two minutes. (You have no control of settings.) If you output from Quicktime7Pro so you can control the settings, it's still faster than it used to be... maybe ten minutes to make a web file on my MBP vs 18 minutes to do the same thing on my 8-core Mac Pro running 10.5.6/QT7.6. Unfortunately, it doesn't seem like the speedup extends to FCS3's new 'share' menu, but I haven't tested that much.
A totally separate workflow speedup unrelated to Snow Leopard has to do with Log & Transfer and Pro Res Proxy settings in FCS3. If you use a camera that can transcode to ProRes(proxy) through log & transfer and you can live with 1920x1080 footage with good color but low bit rate, you'll feel like you've been born again. No rendering for anything at any point. I can't figure out a way to capture tape into proxy files, though.
hope this helps.
Old September 1st, 2009, 02:27 PM   #38
Go Go Godzilla
Images: 15
Because SL is being installed as an "upgrade" rather than a clean install this seems to be the source of most of the troubles. It would be inconceivable that a new 17" MBP that ships with SL could not use it's ExpressCard adapter for all the things it's supposed to.
I don't have time to test this further but so far many of the bugs and failures seem to be around the upgrade path rather than a clean install. Unfortunately most people don't have time to make a clean install.
Old September 1st, 2009, 03:21 PM   #39
Anyone running the Sonnet Pro esata card should be fine. This is the fastest esata card that doesn't use the SIL chipset. I believe its only the sil3132 that's the problem.
No one should ever update any business/production machine on the release of a new O.S. So I'm not sure the drama here is necessary. Apple touched a huge amount of the code in OSX. I think the moderate number of reported problems should be expected.
Snow Leopard is like the switch to Intel. Important to do for the long view. If FCS has some problems, they shouldn't take long to fix.
Don Miller is offline   Reply With Quote
Old September 1st, 2009, 03:29 PM   #40
you can't argue with a confident man.. (Napoleon Wilson, "Assault on Precinct 13")
Greg Quinn is offline   Reply With Quote
Old September 1st, 2009, 06:59 PM   #41
I am not really sure how to even do a fresh install. It seems like a fresh install is kinda hard for me considering my machine is used both for my school work and for my projects.
Old September 1st, 2009, 07:33 PM   #42
If you back up with Time Machine, you can restore everything after the OS install. I think you'll lose any bootcamp partition though.
Jason Lowe is offline   Reply With Quote
Old September 1st, 2009, 08:38 PM   #43
Well loosing Boot Camp is probably something I can't afford right now. I guess I will just stick with 10.5.8. Plus who knows if a fresh install of SL will make my express card work. Seems like a lot of work for a decent chance of it not even being useful.
Old September 2nd, 2009, 02:01 AM   #44
This is how I did it. The preparation took a while, but the install was pretty quick:
1. Downloaded Carbon Copy Cloner (free backup app)
2. Backed up my entire hard drive to an external disk. Doing this makes the external disk bootable, which is a nice get of jail free card (just in case)
3. Inserted SL DVD and started install. When the Mac restarted at the beginning of the process, selected Utilities menu, Disk Utility, and Erased my hard drive.
4. Continued with SL install. Now I have a choice. SL Installer asks if I want to migrate User Accounts, Documents, Applications etc from a backup. I chose this (the alternative is to choose No, and then after the install completes, go to Applications, Utilities, Migration Assistant, and do it then.
Net result - fresh SL install, with all key apps, docs and user data updated.
Nick Gordon is offline   Reply With Quote
Old September 2nd, 2009, 10:14 AM   #45
Yes, but will this fix the Express Card problem?
