iMovie questions - Page 7 at DVinfo.net
Final Cut Suite
Old January 10th, 2004, 08:32 PM   #91
Whew! Thank you very much. I don't want to spend all that time capturing to my HD if it's in the wrong format. FCE2 should be in the stores any day now. I'll leave the video on tape for now.
dB
Dan Brown is offline   Reply With Quote
Old January 24th, 2004, 11:33 AM   #92
iMovie....Sundance Film Festival
Wrangler Note [JL]: Article removed. Please follow this link to read the original.
Rich Sheikh is offline   Reply With Quote
Old January 24th, 2004, 12:00 PM   #93
Great story! And it proves what they say about the art of filmmaking: it's not the equipment you use, it's the story you tell.
Indeed iMovie may not be, what people call, a "professional" NLE program but the truth is that working with limitations can bring out the best of one's creativity.
Stelios G.M.
Stylianos Moschapidakis is offline   Reply With Quote
Old January 24th, 2004, 03:51 PM   #94
Thanks for posting this great story. It is a reminder to work with what you have and improvise. I can slip into thinking I can't make a "real film" until I have this or that equipment, or have access to SFX CDs, or acquire this or that software.
So I have set a goal for myself to do one really crappy short short a month. The crappier, the better. If I finish it and it sucks, I've succeeded. If I don't finish it, but the idea is still brilliant, I've failed.
I doubt if Cauette cared about what other people would think, or if he was using a cartoid vs an omni mic and so on. The irony is that it seems you really have to be passionate and oblivious to 'reality' to do something that gets this kind of critical attention...you can "decide" to be passionate and oblivious because that's how great work gets done...
"Great work" being, I guess, the opposite of what most of us do in this business, which is to make an actual living, in which case you might really want to know the difference between a cartoid and an omni, and you better worry about what someone else thinks, especially if she is your client...
And onward!
Diane Bogosian is offline   Reply With Quote
Old January 24th, 2004, 07:26 PM   #95
<<<--So I have set a goal for myself to do one really crappy short short a month. The crappier, the better. If I finish it and it sucks, I've succeeded. If I don't finish it, but the idea is still brilliant, I've failed.-->>>
Diane, I am with you 100%. Great attitude! Keep it up! I'd like to see one or more of your shorts.
Stelios G.M.
Old January 24th, 2004, 11:22 PM   #96
>>Diane, I am with you 100%. Great attitude! Keep it up! I'd like to see one or more of your shorts.<<
SHOW them to OTHER people?
(I haven't advanced to that stage of enlightenment yet. :)
Actually, Stylianos, that's a great topic for discussion: showing your stuff to others, and how to get "tournament tough."
Old March 2nd, 2004, 04:28 PM   #97
iMovie & FCE
Is there any discernible difference in the quality of the fianl out put (say to DVD) bewteen iMovie and FCE (assuming the same simple basic transitions and ignoring titles)? Or is the advantage of FCE more options and more flexibility.
Thanks, Grant McClintock
Grant McClintock is offline   Reply With Quote
Old March 2nd, 2004, 06:02 PM   #98
There shouldn't be a quality difference, unless you apply some filters that iMovie doesn't have (like color correction filters).
iMovie is great for short projects, but I've found iMovie2 to be catastrophic for large complicated projects (somehow people in my high school had half their media disappear).
Old March 2nd, 2004, 10:23 PM   #99
Taking this thread a little off track to note that for iMovie it's really important not to empty iMovie trash while editing and to be sure you have enough disk space with which to work. iMovie does not fall into the "nondestructive" NLE category. iMovie upgrades all seem to end up being dubbed "the worst yet," but I've had almost no problems with it (in version 3.03) and there are lots of nice, relatively inexpensive plug-ins on the market .
Patricia Kim is offline   Reply With Quote
Old March 11th, 2004, 12:16 PM   #100
imovie guestion
I am trying to make a a filmstrip in imovie. I am using photos from my iphoto library. When I drag a photo to the timeline, i create two photos in the time line.
Say I have the duration set for 5 seconds. I click on a picture of a bridge and drag it to the timeline I get two 5 second photos of the bridge. The two pictures are not linked, I can move them around the timeline. I just can't find out what is causing this.
Any thoughts would be a help.
Joe
Why ask me? I thought you were in charge!
Joe Gioielli is offline   Reply With Quote
Old March 11th, 2004, 12:42 PM   #101
Warden
I don't use iMovie or iPhoto much, but I've never seen it duplicating images unless copied and pasted etc. Have you tried installing iMovie again? Have you added any plugins etc. recently that might be causing a conflict?
Jeff Donald
Carpe Diem
Old March 11th, 2004, 02:16 PM   #102
No. I'm not on the net so I haven't installed any plug ins.
I haven't reinstalled it. It came installed and I'll have to check the manual to see how to reinstall if I want to go that route. I want to avoid that if I can.
I'll keep pokeing around. I must have done something to cause it.
Joe
Old March 11th, 2004, 02:56 PM   #103
I use iMovie and iPhoto, but have never seen this issue discussed. One thing that everyone tells you to do when you run into unusual problems is to trash your preferences (in this case, for both iMovie and iPhoto) and repair permissions, then try again. Oops. Just remembered something. You say you are dragging the photo. The way I import a photo is to make sure the Ken Burns effect is turned off, set the duration, and then click on apply. That sends the photo to the end of the timeline. Possibly if you are dragging the photo as well, that is why you're getting a duplicate?
Old March 11th, 2004, 05:45 PM   #104
I bet your right, Kim. I'll check that.
Old March 26th, 2004, 04:20 PM   #105
Guest
Posts: n/a
I aggree..
I did some intensive editing with Imovie 3 and found out that you should either do one of two things:
empty the trash regularly before it get's too big
or
don't empty it at all.
If it get's too large and you empty it, you will run the risk of corrupting
the entire file. It happened to me. Be careful.
Good luck,
Dan
