Advice? - Installing Full FC STUDIO over Educational Version at DVinfo.net
Final Cut Suite
Old January 19th, 2010, 12:34 PM   #1
Hello all, i need to help, i've been using an educational version of FC Studio with FCP 6. I just bought a complete Version of FC Studio with FCP 7. Should i delete all the old files from the Educational Version before I install the new Version. Will the new version install over the old version? I actually would like it to write over the old version if possible.
Any suggestions would be appreciated.
Shawn
Shawn Dooling is offline   Reply With Quote
Old January 19th, 2010, 01:15 PM   #2
The installer will assume that you are replacing whatever is there and write over it. The most important files that need replacing are the actual programs themselves. You can toss those in the trash before installing.
Old January 19th, 2010, 01:32 PM   #3
Ok Thanks William, i figured i would get asked to overwrite similar File/app names.
Thanks for the help.....appreciate it.
Old January 19th, 2010, 02:25 PM   #4
If you are REALLY worried about it, run this:
FCS Remover - Uninstall Final Cut Studio, Final Cut Pro, Motion, Compressor, Soundtrack Pro, Color, DVD Studio Pro, LiveType, Cinema Tools
If it was me, I would run that before I did the new install. But then, I am psychotic like that.
B-Scene Films
Shaughan Flynn is offline   Reply With Quote
Old January 20th, 2010, 01:24 AM   #5
Go Go Godzilla
Images: 15
Shawn,
The FCS installer is very similar to the installer for Snow Leopard; it's an "intelligent" install in that it only writes the code required to install its' packages and deletes old code it's replacing. You should be just fine with a normal install/upgrade.
However I would suggest running Onyx for Mac right after you complete the install; this will clear up all the old cache and directory files that were associated with the older version of FCS and prevent any file forks from searching for a now defunct version.
Old January 20th, 2010, 04:37 AM   #6
FCS Remover
as Shaughan Flynn suggested, I would run FCS remover. Overriding files can open up the possibility of corruption. I would even go as far as install a clean OS on the drive and then install FC Studio. Also FYI, Final Cut Studio academic is a full version. It has all the features as FCS. The only difference is upgrade licensing. Final cut express is however a watered down version.
Just make sure you back up your keyboard and button bars. Do not backup preference files. There is one in the preferences folder and 3 inside the final cut pro user data folder. These get corrupt easily. When launching FCP the first time on a new system, new preference files will be made.
Eric Dyer is offline   Reply
