FCP 4.0 with XL2 - Help at DVinfo.net
Final Cut Suite
Old December 4th, 2005, 08:15 PM   #1
Hi,
This is my first time using FCP, so I'm not sure how to capture; I shot my footage with an XL2 16x9 advanced 24p and eventually plan to make an anamorphic DVD with it. As I've never used FCP, I'm not sure what settings to capture this with. Any help would be really appreciated.
Joe Kramer is offline   Reply With Quote
Old December 4th, 2005, 08:41 PM   #2
First, if you are really running FCP 4.0 then you should update to FCP 4.5 HD, which is free:
http://www.apple.com/support/downloa...lcutprohd.html
What version of MacOSX are you running? See the following related thread:
http://www.dvinfo.net/conf/showthread.php?t=55436
In FCP 4.5 go to the Final Cut Pro menu and choose "Easy Setup." Check the little box that says "show all." Now pull down the menu to "DV-NTSC 24- (23.98) Advanced Pulldown. Now create a new project with these settings. In the capture settings and sequence settings you may also need to click the "anamorphic 16:9" check box.
Old January 3rd, 2006, 12:47 AM   #3
Thanks a lot, I got it to work. Now I just have one more question - how would I do this offline? I see a lot of offline options, but none for Advanced Pulldown. Which one would I choose?
Thanks.
