color correcting dark exposure at DVinfo.net
Final Cut Suite
Old February 17th, 2007, 04:55 AM   #1
Hi,
We're trying to color correct shots that are back lit - i.e. subject's face is dark against bright outdoor background. Any tips on how to bring out the subject's face without excessive artefacts?
Thanks.
Zareh Tjeknavorian is offline   Reply With Quote
Old February 17th, 2007, 03:13 PM   #2
Depends on how heavily back lit the piece is...as far as technique goes, you could use the image itself as an alpha mask, then correct the background darker and the foreground slightly lighter and hope that the lowering of the contrast of the image will help the eye itself pull out more light and detail from the dark face.
Web Youtube Facebook
Cole McDonald is offline   Reply With Quote
Old February 17th, 2007, 10:42 PM   #3
try duplicating the image on a higher track, then right clicking the higher track and change Composite Mode to Add ... use a Garbage Matte or Mask Shape combined with the Opacity of the clip on the higher track to limit the area of the effect
you might also like Marcus Herrick's Facelight plugin that you can grab for free here: http://www.haiku.com.au/2005/08/fina...-plug-ins.html
and search around ... i'm sure i saw a tutorial on exactly this topic floating about the other day
Andy Mees is offline   Reply With Quote
Old February 18th, 2007, 02:38 PM   #4
Andy, Cole,
Many thanks to you both for finding the time to write. I'm going to try these options - and the download - and will share my results.
Zareh
