Change DVD sEtting on DVD STudio Pro at DVinfo.net
Final Cut Suite
Old March 4th, 2007, 09:01 AM   #1
Hey all,
I was wondering if there was a way to permantly change the default DVD drive on my macboo. My internal was on the fritz, so I bought an ecternal DL burner. It works great for everything except if I want use the "burn" function. As you know, when you click burn, it tries to access the default drive. This means I have to use the build/format button, select the drive I would like to use, click reuse (because I already built the project), then click build and burn.
I was hoping there was a way to make DVD sTudio recognize my external drive as my default drive.
Bryon<><
Commandment #11- "Thou shalt Render as thou goest."
"The fear of the Lord is the beginning of wisdom" (Prov. 1:7)
Bryon Akerman is offline   Reply With Quote
Old March 5th, 2007, 05:21 PM   #2
Hey Bryon,
you could try using patchburn....www.patchburn.de, its supposed to help fix some issues with makeing burners more compatible with OS X... I've never tried it so I don't know if it would help at all.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply
